> Valve Covers, Are they all the same?
Allan
post Dec 3 2004, 10:48 AM
Teenerless Weenie
Are all valve covers the same? 1.7 - 2.0? And are they interchangable from left to right and can they be straightened easily. I have one with the outside lip that is bent.
Replies(1 - 13)
SLITS
post Dec 3 2004, 11:54 AM
"This Utah shit is HARSH!"
Uh yeah, except for those made with tabs to hold the gaskets - not sure when they started.
Jake Raby
post Dec 3 2004, 11:55 AM
Engine Surgeon
The early 1.7 had different covers. They are a different shape but will still fit a 2.0 head or any other..
They are swappable from left to right..
Install with the vw logo UPSIDE DOWN, thats the right way..
Allan
post Dec 3 2004, 12:11 PM
Teenerless Weenie
What about repairing these things if they get warped or bent?
Mueller
post Dec 3 2004, 01:06 PM
914 Freak!
QUOTE(Headrage @ Dec 3 2004, 11:11 AM)
that depends on you and your skills...might just be better off finding a known good set....
Allan
post Dec 3 2004, 01:08 PM
Teenerless Weenie
Thanks guys. I don't have the equipment to really ensure that the surfaces are flat and true so I'll post a WTB in the classifieds.
Brando
post Dec 3 2004, 03:15 PM
BUY MY SPARE KIDNEY!!!
Might sound like a dumb question, but since we're on the topic of valve covers...
Do the aluminum empi covers with finning on them actually make a difference or no?
Dave_Darling
post Dec 3 2004, 03:28 PM
914 Idiot
Yes, they do. They drastically increase the amount of oil you find on your heat exchangers... Plus they add stress to fasteners that are not very over-engineered in the first place (the rocker arm retaining studs).
IMHO, they suck.
--DD
MattR
post Dec 3 2004, 03:46 PM
QUOTE(Dave_Darling @ Dec 3 2004, 01:28 PM)
Hmm, more oil on the heat exchangers, eh? (IMG:style_emoticons/default/idea.gif)
URY914
post Dec 3 2004, 03:49 PM
No, there are two kinds. Those that leak and those that don't. They look alot alike.
As far as the cast aluminim ones, they suck.
Paul
Mike D.
post Dec 3 2004, 04:25 PM
OK, It runs now, and pretty good too!
IMHO, they suck.
--DD
AND they wont fit under your stock cooling tins without a little help... (IMG:style_emoticons/default/smash.gif) ...the tin that is.
-Mike D.
BTW - I have three sets of brand new valve covers, Still have the Porsche stickers on them. Not cheep but that is because I paid too much for them (IMG:style_emoticons/default/huh.gif)
Jake Raby
post Dec 3 2004, 05:13 PM
Engine Surgeon
Stock or nothing..
The bolt on ones have weak hardware that sucks. They can easily pop right off and take the rockers with them..
If you want something nice I sell carbon fiber ones that use stock gaskets and bails and don't leak.
ChrisFoley
post Dec 3 2004, 06:01 PM
I am Tangerine Racing
Some early ones have a rounded countour that interferes with the rocker adjusters when a big cam is used. The later ones have straight sides that give more room inside.
The cast aluminum ones can be modified to not leak. The gasket surface has to be milled, and the flat where the nut goes has to be milled on a 3.5 degree angle, since the rocker stud isn't perpendicular to the gasket surface. Generally speaking, it's not worth the added expense.
I think the hardware fails because people overtighten them trying to eliminate the leaks. (IMG:style_emoticons/default/unsure.gif)
Allan
post Dec 4 2004, 09:56 AM
Teenerless Weenie
Thanks again guys. Slits is bailing me out again. (IMG:style_emoticons/default/smilie_pokal.gif)
- Lo-Fi Version Time is now: 14th July 2025 - 10:48 PM
