Radiator Line off shelf reducers?, GM Radiator to a Renegade Kit |
pete |
Jul 10 2013, 02:17 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I bought a SBC 350 with a Renegade kit. I just purchased a radiator with a 1 1/2" top inlet and an 1 3/4 bottom outlet. I need to reduce these to 1" at the top and 1 1/4" at the bottom. Has anyone bought items that work off the shelf from Home Depot or lowes etc? Any suggestions?
BIGKAT_83 |
Jul 10 2013, 02:59 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
These guys Jags That Run can get you anything you need.
Attached image(s) |
bulitt |
Jul 10 2013, 04:29 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Good stuff, machined billet, and fast shipping!
Rotary'14 |
Jul 10 2013, 06:41 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I have bought copper plumbing reducers and put a bead on it to hold the hose on. It works great,, and was cheap too. I can put a bead on some copper reducers for you if you don't find anything else.
partwerks |
Jul 11 2013, 06:26 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I just made mine by using one pipe that would fit inside the other, and or roll and short piece of sheet metal around the end for a shim to fit.
pete |
Jul 11 2013, 06:43 AM
I have bought copper plumbing reducers and put a bead on it to hold the hose on. It works great,, and was cheap too. I can put a bead on some copper reducers for you if you don't find anything else. That's what I was thinking. I went to HD yesterday. They seem to be stocking more Sharkbite fittings then copper fittings. I'll try a plumbing supply store. |
pete |
Jul 11 2013, 06:44 AM
Thanks. Looks great but expensive. I'll give them a call. |
pete |
Jul 11 2013, 06:47 AM
Thanks. Looks great but expensive. I'll give them a call. Actually, they are pretty reasonable. Thanks! |
pete |
Jul 12 2013, 07:00 AM
Thanks for the info everyone. I ordered from Jags that run. Two machined fittings for $25. Free shipping from CA. Can't beat that. Better then driving all over the place trying to find copper fittings.
I was looking at coolant hose from McMaster.com. Seems kind of expensive. Plus there is a min of 5' of each size. Any other sources for just straight 1 1/2" and 1 3/4" hose? I'm finding none of the auto parts stores around here sell it by the foot. I probably just need 2-3' of each. |
BIGKAT_83 |
Jul 12 2013, 07:09 AM
O Rielly auto parts has both the sizes you need in gates green stripe hose.
pete |
Jul 12 2013, 07:13 AM
andys |
Jul 12 2013, 11:26 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I don't remember the McMaster-Carr hose as being particularly expensive; that's what I used. NAPA has straight hose by the foot.
Andy |
JRust |
Jul 12 2013, 11:40 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I also have used muffler pipe reducers. Just about every autoparts store has them. Billet is much better but in a pinch these work fine. Going from hose to hose that is
bulitt |
Jul 12 2013, 11:42 AM
NAPA sells the 1" for 5.98$/ft and the 1-1/4" for 5.77$ per foot. (yellow stripe). Which is what most V8 conversion run front to back.
pete |
Jul 12 2013, 12:04 PM
NAPA sells the 1" for 5.98$/ft and the 1-1/4" for 5.77$ per foot. (yellow stripe). Which is what most V8 conversion run front to back. Thanks, I'm going to stop in at NAPA tomorrow. Their 1 1/2 + 1 3/4 is a little more expensive per foot then McMaster, but McMaster has a 5' min of each. And I'm going to look into the 1" and 1 1/4". I can go to Renegade and get enough green stripe in both sizes to reach the engine apparently for $120. |
Cap'n Krusty |
Jul 12 2013, 12:50 PM
O Rielly auto parts has both the sizes you need in gates green stripe hose. Checked, no stores in the northeast. Checker/Schucks/Kragen/O'Reilly. They're all the same company, sell all the same second and third rate crap, and they're everywhere. This is NOT an endorsement! Actually, you made the right decision to go with Jags That Run. The Cap'n |
Lo-Fi Version | Time is now: 28th May 2024 - 03:04 PM |
