Rear window defroster, Harness needed. |
Teknon |
Dec 4 2004, 10:40 AM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
My back window was flapping around, so I picked up another window with a defoster in it. Does anyone have a harness or a schematic for it's install.
Joe (IMG:style_emoticons/default/boldblue.gif) |
SirAndy |
Dec 4 2004, 02:24 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Teknon @ Dec 4 2004, 08:40 AM) My back window was flapping around, so I picked up another window with a defoster in it. Does anyone have a harness or a schematic for it's install. no harness, but the install is easy. you'll need: - one round black relay just like the others on your relay board. - a few feet of wires. the original wires are "Yellow/Red" and "Green". when looking at your relay board, - the relay goes into the socket closest to the front of the car. - the 2 wires are connected to a 2-prong connector just in front of the 2 fuses. the yellow/red wire goes onto the left prong, the green wire goes onto the right prong. if you have a haynes manual (which you should!) go to page 147 for a schematic of the relay board. the defrogger wireing is the same through all the years. in the haynes manual, the defrogger relay is #52, the wire connector is just in front of that. i doesn't look like the main harness of our cars has a wire for the dash switch build in, so you would have to figure out how the switch was included in that circuit. (IMG:style_emoticons/default/cool.gif) Andy |
Teknon |
Dec 4 2004, 05:43 PM
(IMG:style_emoticons/default/boldblue.gif) "OUTASIGHT" Explained so that even a fool can't err. Thank you so much. Joe
Teknon |
Dec 4 2004, 05:47 PM
(IMG:style_emoticons/default/boldblue.gif) I'll just run it to a glow rocker. This is no concourse.
TheCabinetmaker |
Dec 4 2004, 05:54 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
There is already a hole for it in your dash. It's to the left of the cigarette lighter behind the vinyl.
TheCabinetmaker |
Dec 4 2004, 05:55 PM
BTW, make sure the wires on the glass work before you go to all that trouble.
Teknon |
Dec 4 2004, 07:11 PM
Looks like relay point 87A goes to switch then to ground..????????????
Lo-Fi Version | Time is now: 31st May 2024 - 10:18 PM |
