CV Joint Assembly, or disassembly |
cwpeden |
Jul 19 2013, 10:02 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I was looking though my boxes of parts and found 4 CV's a friend gave me. Three are good and one was assembled wrong.
Small space to small space...etc. I've found videos and text versions of assembly and they say what not to do but not how to undo it. CV's look like new. I would like to use them. Anyone managed to fix this? Help. |
stugray |
Jul 19 2013, 11:02 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
SirAndy |
Jul 20 2013, 12:16 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Anyone managed to fix this? Many moons ago i posted a thread with pictures on how to assemble them ... (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Jul 20 2013, 12:20 PM
Anyone managed to fix this? Many moons ago i posted a thread with pictures on how to assemble them ...(IMG:style_emoticons/default/idea.gif) Found it ... The fun part starts here: http://www.914world.com/bbs2/index.php?s=&...st&p=458313 (IMG:style_emoticons/default/popcorn[1].gif) |
stugray |
Jul 20 2013, 01:43 PM
The really fun part is when you try to "fix one" that is assembled wrong...
Pop out inner & rotate to next index position Reassemble Find you are STILL wrong.... WTF? A correctly assembled CV on the first try is like a unicorn.... Stu |
cwpeden |
Jul 21 2013, 05:00 PM
That's the problem. One CV out of four is wrong and I cant get it apart. I cant get the inner to move. Its stuck in the 'neutral' position. Flat.
stugray |
Jul 21 2013, 08:58 PM
There is no secret. Just "flip" the inner race until a ball falls out.
Stu |
76-914 |
Jul 22 2013, 08:26 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Have you tried slipping it on a half shaft to give you some leverage on the inner race?
Eric_Shea |
Jul 22 2013, 06:41 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I don't believe they go together wrong. Probably just tight with no lube.
Porsche930dude |
Jul 22 2013, 07:18 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
fiddle with it long enough and it will come apart. you need to move the cage along with the inner race . the cage needs to be at an angle half way between the inner and outer hubs to assemble or dissasemble them. its not hard once you get the hang of it.
stugray |
Jul 22 2013, 07:28 PM
QUOTE I don't believe they go together wrong Sure they do. I took two spares off the shelf. With one I "flipped" the inner race out, and moved it to the next set of slots. They are harder to get together wrong, but you can do it. Left one is right, right one is wrong. ( I should have thought that out ....:-) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1374542880.1.jpg) When they are right, you have small end on inner with large end of outer. Wrong is: small with small, large with large. Stu |
SirAndy |
Jul 22 2013, 07:50 PM
When they are right, you have small end on inner with large end of outer. Wrong is: small with small, large with large (IMG:style_emoticons/default/agree.gif) |
Eric_Shea |
Jul 22 2013, 10:08 PM
Learnt something new... (IMG:style_emoticons/default/blink.gif)
I've always done small to large and didn't think you even could get them together the wrong way. |
rjames |
Jul 23 2013, 12:55 PM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Probably doesn't need to be said, but the innermost piece is tapered and only goes on the shaft one way, so plan accordingly when assembling the CV.
OU8AVW |
Jul 23 2013, 02:51 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 1st June 2024 - 08:59 AM |
