Rear Wind Defroster Switch, Lighted ? like Fog Switch ? |
jim_hoyland |
Dec 5 2004, 01:49 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Doe the center button on the Rear window defroster switch light up like the fog switch ?
SirAndy |
Dec 5 2004, 01:51 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(jim_hoyland @ Dec 5 2004, 11:49 AM) Doe the center button on the Rear window defroster switch light up like the fog switch ? yes ... |
ejm |
Dec 5 2004, 03:26 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The fog lights and heated rear window actually use the same switch
only the logo in the cap is different |
jim_hoyland |
Dec 5 2004, 03:52 PM
Is the bulb replaceable ? Tried to pry the green botton up, but it s in there pretty good. This appears to be an original switch; mostly metal-not plastic
Rusty |
Dec 6 2004, 10:32 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
The black plastic surround should pry back a bit so you can remove the disk. Maybe you can soften it up with a heat gun.
-Lawrence |
Lo-Fi Version | Time is now: 1st June 2024 - 12:54 AM |
