Porterfield Pads, Fitting issue rear |
CG-914 |
Jul 23 2013, 09:57 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Got a set of rear rotor and Porsterfiel pads (R4S).
When putting them on I realized that the top pin is bigger, where it is holding the pads. Also the old pads have two different size holes (textar) The new Porterfields have two small holes. (IMG:style_emoticons/default/ar15.gif) Is that a known issue? I was planing on drilling them out tomorrow... |
McMark |
Jul 23 2013, 10:00 PM
Yup. Not uncommon. I don't know which work and which don't, etc. But yeah, just drill them.
wildman |
Newbie Group: Members Posts: 34 Joined: 24-May 11 From: Oklahoma City, OK Member No.: 13,112 Region Association: Southwest Region |
Yep, known issue, look near the bottom of Eric's description here
http://www.pmbperformance.com/catalog/item...563/6732655.htm (IMG:style_emoticons/default/biggrin.gif) |
Trekkor |
Jul 23 2013, 10:02 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I seem to remember using a 1/4 inch drill bit on every set I've installed.
KT |
CG-914 |
Jul 23 2013, 11:22 PM
Are there any modification needed for the front porterfields?
Chris H. |
Jul 24 2013, 07:44 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I just installed a set of front pads and they went in like buttah. No mods needed. Haven't done the back ones yet so thanks for the heads-up.
sixnotfour |
Jul 24 2013, 07:22 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
In the Old Days the rear 914 pads were location specific, as they had a slight taper, nowadays they are not, So orientation is non specific..drill em out.
Brian_Boss |
Jul 25 2013, 09:36 AM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
I think that pretty soon this (the need to enlarge one hole) will be true for all rear pads. It seems the OEM's like Textar, Jurid, etc. are doing the same thing as Porterfield in order to commonize the 914 rear pad with one or more other applications.
We recently had a customer who wanted stock pads that did not need to be drilled and they are hard to find. |
steuspeed |
Jul 25 2013, 11:45 AM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Yup! Check out my rear brake caliper thread post #9.
http://www.914world.com/bbs2/index.php?sho...;hl=rear+brakes |
Lo-Fi Version | Time is now: 8th June 2024 - 05:41 PM |
