Pop Pop Pop, Need Help with My Carbs |
szuccaro |
Jul 27 2013, 11:25 PM
ZUKE Group: Members Posts: 200 Joined: 27-June 03 From: Cameron Park, CA Member No.: 862 Region Association: Northern California |
Hi guys.... my carbs are way overdue for a tuning, and well, I'm no good at it. I'd like to be able to enjoy driving my 914 again, but afraid to mess up the carbs even more. Anyone in the San Jose area interested in helping a fellow teener? I would appreciate it very much. Let me know if mid-August would be good. Thanks in advance. steve_zuccaro@comcast.net
Rand |
Jul 27 2013, 11:57 PM
Nice looking car. If the pops are out the top, it's probably lean. (pops out the back are more likely exhaust leaks or rich.)
rhodyguy |
Jul 28 2013, 07:03 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
symptoms? what is going wrong and when does it happen? specific details.
pilothyer |
Jul 28 2013, 09:02 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Man, get a load of that garage.......very impressive, so neat and clean. Nice looking 914 too. (IMG:style_emoticons/default/biggrin.gif)
Eric_Shea |
Jul 28 2013, 12:34 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hey Steve,
Read the section on installation and also performance tuning: http://www.performanceoriented.com/technic...tm#Installation Best Weber advice I've found. |
szuccaro |
Jul 28 2013, 02:17 PM
Nice looking car. If the pops are out the top, it's probably lean. (pops out the back are more likely exhaust leaks or rich.) mixture problems.... not exhaust leak....pops out the tail, i think..hard to determine for sure while driving....becomes more pronounced when decelerating. I dont know which screws to adjust on the carbs.... which one is for mixture and which for idle speed. Need an expert to help me...in person. Help. |
Rand |
Jul 28 2013, 03:20 PM
Nice looking car. If the pops are out the top, it's probably lean. (pops out the back are more likely exhaust leaks or rich.) mixture problems.... not exhaust leak....pops out the tail, i think..hard to determine for sure while driving....becomes more pronounced when decelerating. I dont know which screws to adjust on the carbs.... which one is for mixture and which for idle speed. Need an expert to help me...in person. Help. You need to confirm if from the tail. Especially if on decel, I'm thinking you might want to reconsider checking out the exhaust system before assuming it's carbs. If you just want to take it somewhere, I think McMark is worth the drive. http://www.originalcustoms.com/ |
ChrisFoley |
Jul 28 2013, 06:09 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
An obstructed jet will cause popping, especially on decel.
What happens is that cylinder lean misfires, allowing unburnt fuel into the hot exhaust system where it finally ignites. |
ThePaintedMan |
Jul 28 2013, 07:12 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
An obstructed jet will cause popping, especially on decel. What happens is that cylinder lean misfires, allowing unburnt fuel into the hot exhaust system where it finally ignites. That makes a ton of sense Chris. I always wondered what the mechanics were behind that. (IMG:style_emoticons/default/pray.gif) I would take Chris' thoughts as a good place to start. Checking the idle jets out is a good place to start, and something that should probably be done periodically anyway. Then move on to exhaust. |
r_towle |
Jul 28 2013, 07:31 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Clean your idle jets, then if it continues, bring it up to McMark.
To clean the idle jets, you are not changing the tuning at all. Just remove them and blow out the crud, then reinstall. Each jet has a rubber o ring on the neck of the jet holder, so be careful not to pinch it. Rich |
szuccaro |
Jul 28 2013, 10:20 PM
Thanks everyone for the info. I appreciate it.
Attached image(s) |
McMark |
Jul 29 2013, 12:53 AM
If you feel like driving up north, I'd be happy to host a carb-tuning event.
Heading down your way to pick up a 2002 this week. (IMG:style_emoticons/default/driving.gif) |
Eric_Shea |
Jul 29 2013, 07:24 AM
Lo-Fi Version | Time is now: 8th June 2024 - 12:06 PM |
