> Sealing the front cowl, and waterproofing the front trunk
ericoneal
post Jul 31 2013, 07:34 PM
I currently do not have a fresh air box, but would like to keep water from running into my trunk during a rain or carwash. Any ideas as to how to tastefully seal the front grill? I'm considering maybe a plate underneath, sealed with silicone. Suggestions?
Thanks
Replies(1 - 19)
Mike Bellis
post Jul 31 2013, 07:40 PM
Resident Electrician
QUOTE(ericoneal @ Jul 31 2013, 06:34 PM) *
Thanks
Tastefully... Weld and paint.
Or, put the fresh air box back in
Or, I once used polyurethane tape on the top to seal it temporarily.
Jeff Hail
post Jul 31 2013, 07:50 PM
Thanks
Weld it up! One less place to leak.
r_towle
post Aug 1 2013, 06:53 AM
Custom Member
QUOTE(ericoneal @ Jul 31 2013, 09:34 PM) *
Thanks
make a box about 3/4 inches deep, rectangular.
Put a drain in the corner and run the drain hose like the original, down under the gas tank and to the ground.
Rich
ericoneal
post Aug 1 2013, 10:04 AM
I may give that a try as welding is not an option. I will need to remove the gas tank to run the drain line, right?
QUOTE(r_towle @ Aug 1 2013, 08:53 AM) *
Thanks
Rich
r_towle
post Aug 1 2013, 10:45 AM
Custom Member
no, you should be able to slide a hose about 3/4 inch diameter behind and down through the round hole at the bottom specifically for the drain hose from the original box.
The hold is towards the middle of the car in relationship to the big ass hole you can put your hand into underneath...
If I recall correctly, you can flick the hose into that hole via the large hole.
Rich
r_towle
post Aug 1 2013, 10:47 AM
Custom Member
BTW, this is not my original idea...there is a thread here with pictures, and lots of details...
All you have to do is find it.
ericoneal
post Aug 1 2013, 01:45 PM
No luck searching.. Search tool on this site is very sensitive...
QUOTE(r_towle @ Aug 1 2013, 12:47 PM) *
TheCabinetmaker
post Aug 1 2013, 01:55 PM
I drive my car everyday
Heres a better sarch engine for ya.
https://www.google.com/cse/home?cx=00240834...772:ajvfxschcgc
ThePaintedMan
post Aug 1 2013, 02:36 PM
I have way too many other projects, but eventually I was thinking of doing something like this:
https://www.youtube.com/watch?v=n77otHE8peA
Saw one on a fastback a few years ago and liked it.
ericoneal
post Aug 1 2013, 08:40 PM
Now you've done it! I am going to make on of these...
QUOTE(ThePaintedMan @ Aug 1 2013, 04:36 PM) *
barefoot
post Aug 4 2013, 04:49 PM
Thanks
When I got my car, it had no air box but was sealed off with a stainless plate underneath. I'm adding air box and all the other stuff.
You can have my plate for $10, it's very well made.
Barefoot
ericoneal
post Aug 4 2013, 06:54 PM
THanks. I considered the stainless steel route, but I was able to pick up some Plexiglass at Lowes today. The cut it for me and let me have it for free since it was so small. Next I'm going to get some wingnuts (and weather strip) and secure it like the video above, but will probably only do that in rain or washing.
Will post pictures when finished.
QUOTE(barefoot @ Aug 4 2013, 06:49 PM) *
Thanks
Barefoot
dfelz
post Aug 4 2013, 09:09 PM
beach bum
QUOTE(barefoot @ Aug 4 2013, 03:49 PM) *
Thanks
Barefoot
Got any pictures? may be interested?..
7TPorsh
post Aug 4 2013, 10:50 PM
7T Porsh
wish there was something for the rear side grills...
7TPorsh
post Oct 1 2013, 05:04 PM
7T Porsh
Does anyone know the name of this type of fastener?
http://www.youtube.com/watch?v=5RdvFbg9ykM
914forme
post Oct 1 2013, 05:13 PM
Dzus Fasteners they are sold all over the place.Ebay They set in at different depths so make sure you get the proper ones as your cowl setup will be deeper than holding two 22 ga piece of sheet metal together.
7TPorsh
post Oct 1 2013, 05:28 PM
7T Porsh
I'm thinking of making one of these for the teener out of thin gauge steel or aluminum. Pinted the color of the car.
I don't have heat or air and just get whistling air sounds on the freeway.
post Oct 1 2013, 05:30 PM
Resident German
Suggestions?
Duct tape in body color ... (IMG:style_emoticons/default/rolleyes.gif)
Jeff Hail
post Oct 1 2013, 05:49 PM
QUOTE(SirAndy @ Oct 1 2013, 04:30 PM) *
Suggestions?
.....with duct tape, Juicy Fruit gum foil wrapper, ball of twine, a string of mig wire and a pocket nail clipper you can save the world and quite possibly finish Daytona!
- Lo-Fi Version Time is now: 11th December 2025 - 02:45 AM
