EJP914 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 ![]() |
Would anyone know the size of the jet used for the fuel mixture in a Weber 32/36 DFV carb? Mechanic working on my car cannot get the fuel mixture straightened out (too rich) and has suggested I order 3 progressively smaller jets for him to try. This doesn't sound too difficult, but I don't know the size I am starting with. If no one on the board knows, any suggestions on where I can find this info?
I know a single carb is not the ideal set up, but it's what I own at present. Thanks in advance for the help. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Based upon the design, a single carb always runs rich, especially when the car is cold.
The distance of the runners allows the fuel/air mixture to separate and the fuel become heavier prior to entering the heads. This setup, while it works, is the worst setup for our cars. A set of dual carbs is much better. Ray Mital, rmital here has tweaked his setup and got it working to a tolerable level. Try sending him a pm here to see what he did. |
dirk9141973 |
Unregistered ![]() |
Based upon the design, a single carb always runs rich, especially when the car is cold. The distance of the runners allows the fuel/air mixture to separate and the fuel become heavier prior to entering the heads. This setup, while it works, is the worst setup for our cars. A set of dual carbs is much better. Ray Mital, rmital here has tweaked his setup and got it working to a tolerable level. Try sending him a pm here to see what he did. (IMG:style_emoticons/default/agree.gif) tough to setup because of length of intake and in cool weather 60 deg you can get frost on tubes temporary carb set up ! |
mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
How are the dual single barrel carbs? I'm going to upgrade from my single progressive but not sure I want to spend or deal with the dual two barrels
Sean Based upon the design, a single carb always runs rich, especially when the car is cold. The distance of the runners allows the fuel/air mixture to separate and the fuel become heavier prior to entering the heads. This setup, while it works, is the worst setup for our cars. A set of dual carbs is much better. Ray Mital, rmital here has tweaked his setup and got it working to a tolerable level. Try sending him a pm here to see what he did. |
mrholland2 |
Although I'm considering changing it out, I have a single progressive with a modified air cleaner assembly that uses an HE for a heat riser.
r_towle |
Meh, but they can be made to run good.
Dual webers are the best carbs to use, and they are really not hard to setup if you ask for advise. |
mrholland2 |
r_towle |
Fuel injection
mrholland2 |
r_towle |
It actually is an option...
The motor is built for fuel injection, so the camshaft won't do better with carbs, it will do worse. But, a well setup set of dual carbs is much better than your single carb, they are easy to tune, and you can buy a kit from cb performance with everything you need. Now, once you see what that costs, fuel injection is not really that far out of an idea. Plenty of guys have used fuel injection parts here, or on ebay.... If fuel mileage is your number one concern, fuel injection is the best choice. You need to decide what you want from the car and head in that specific direction. Rich |
mrholland2 |
New motor. . with a "carb" camshaft. Sorry I didn't mention that.
It actually is an option... The motor is built for fuel injection, so the camshaft won't do better with carbs, it will do worse. But, a well setup set of dual carbs is much better than your single carb, they are easy to tune, and you can buy a kit from cb performance with everything you need. Now, once you see what that costs, fuel injection is not really that far out of an idea. Plenty of guys have used fuel injection parts here, or on ebay.... If fuel mileage is your number one concern, fuel injection is the best choice. You need to decide what you want from the car and head in that specific direction. Rich |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I've always wondered why the single carb has bad reviews?
VW used a single center carb for what, 30 years or more? KT This post has been edited by Trekkor: Aug 4 2013, 12:14 AM |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
I've always wonder why the single carb has bad reviews? VW used a single center carb for what, 30 years or more? KT Yeah, but the 914 isn't a VW...it's a Porsche! (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/hide.gif) |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
I've always wondered why the single carb has bad reviews? VW used a single center carb for what, 30 years or more? Yes, on a Type 1 they did. But the Type 4 layout is much wider and with the low runners going to each cylinder, fuel that is mixed in the center of the engine then has to travel the length of that whole runner, then make an almost 180 degree bend before entering the cylinder. The Type 1 carb runners are much shorter, because of the engine's smaller physical size and are heated (to help keep the fuel atomized in the runner). Even then, not an ideal setup. Hence why VW pushed fuel injection so much when they moved to the Type 4. |
Nozzle |
Member ![]() ![]() Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region ![]() |
I've always wondered why the single carb has bad reviews? VW used a single center carb for what, 30 years or more? KT I was curious about that myself. My '66 bug had a factory single carb on it's type I engine and seemed to run fine or at least as well as intended. Maybe the key is the way the type VI was originally designed for EFI while the type I was designed for a carb application? I don't know for sure but I don't think VW or Porsche used anything but EFI on the type VI from the factory. Sorry for the posting high-jack... (IMG:style_emoticons/default/biggrin.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Have you ever talked to a VW mechanic about people who remove the heat risers from their engines? If you do, be prepared to learn some new curse words...
Those are major factors as to why the single-carb setup works better in the Type I motors than in the Type IV motors. I talked to mrholland2 at the last 9:14 breakfast up at Alice's, and it sounds like his cobbled-together setup may actually make the dreaded Weber Progressive work decently. He has heat exchanger air ducted into the carb, which helps with the icing and mixture drop-out problems. A pair of baby carbs (e.g., single-throat 36es or a similar small throat, single or dual throat) would likely work OK and might get better fuel mileage, at the expense of top-end power. I have heard someone on one of the forums say that they got good mileage and lousy top-end from a pair of small carbs. So it might be one way to go. But then, that will be fighting against the carb camshaft, which is optimized for better top-end and not for low-RPM running. So.... --DD |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I've always wondered why the single carb has bad reviews? VW used a single center carb for what, 30 years or more? KT I was curious about that myself. My '66 bug had a factory single carb on it's type I engine and seemed to run fine or at least as well as intended. Maybe the key is the way the type VI was originally designed for EFI while the type I was designed for a carb application? I don't know for sure but I don't think VW or Porsche used anything but EFI on the type VI from the factory. Sorry for the posting high-jack... (IMG:style_emoticons/default/biggrin.gif) '72-'74 Bus had dual Solex.carbs, '74 European market 914 had the same carbs. The Cap'n |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
I've always wondered why the single carb has bad reviews? VW used a single center carb for what, 30 years or more? KT Yep ,72 Super Beetle , and come winter time here where I live , I ducttapped the hood grill intake slots and still had runner frosting . Even had it freeze up to the point it died on me and got a tow home , With exhaust heat cross over working. Jack |
Trekkor |
Did the type four motors that were equipped with carbs from the factory use a different cam?
KT |
mrholland2 |
oi (IMG:style_emoticons/default/wub.gif)
Have you ever talked to a VW mechanic about people who remove the heat risers from their engines? If you do, be prepared to learn some new curse words... Those are major factors as to why the single-carb setup works better in the Type I motors than in the Type IV motors. I talked to mrholland2 at the last 9:14 breakfast up at Alice's, and it sounds like his cobbled-together setup may actually make the dreaded Weber Progressive work decently. He has heat exchanger air ducted into the carb, which helps with the icing and mixture drop-out problems. A pair of baby carbs (e.g., single-throat 36es or a similar small throat, single or dual throat) would likely work OK and might get better fuel mileage, at the expense of top-end power. I have heard someone on one of the forums say that they got good mileage and lousy top-end from a pair of small carbs. So it might be one way to go. But then, that will be fighting against the carb camshaft, which is optimized for better top-end and not for low-RPM running. So.... --DD What. about returning FI to a car with a Carb camshaft? |
Lo-Fi Version | Time is now: 10th June 2024 - 06:22 PM |
