She's Running!, Another 914 saved |
newdeal2 |
Dec 7 2004, 01:36 PM
Unregistered |
WEll...I did it! I re built my first engine, a 2 Liter TYpe 4 and it's running cool and smooth! Just need to fine tune things and I will drop it off the stands a away I go!
QUESTION: I ran the car for a while at about 2000 rpm. How soon must I adjust the valves and I assume I should change the oil in about 500 or should I do that asap? Oh i have a teeny leek but it's nothing serious. What do you expect from my first (IMG:style_emoticons/default/laugh.gif) |
Stutgart46 |
Dec 7 2004, 01:37 PM
Stutgart46 Group: Members Posts: 396 Joined: 20-November 03 From: Houston, TX Member No.: 1,365 |
Good job. (IMG:style_emoticons/default/smilie_pokal.gif)
If you had to do it again, what would you do different? |
GaroldShaffer |
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Excellent. (IMG:style_emoticons/default/smilie_pokal.gif)
Rhodes71/914 |
Dec 7 2004, 01:38 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
So what ended up being your ignition problem? Was the dizzy 180 deg off.
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
So what was the problem that it won't start???
Paul |
newdeal2 |
Dec 7 2004, 01:50 PM
Unregistered |
I have the dizzy in wrong and had to move the wires over 1 space. My Porsche Mech/Friend [Frank Eibell, he did the heads and crank work]will fix it when he does my valve adjustment. He told me to run it in for about 500 miles and bring it by so he can do a once over. I am going to check the compression now...I am a glutten you know!
This is so cool! (IMG:style_emoticons/default/cool.gif) |
Root_Werks |
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/smilie_pokal.gif) Cool! Show us pics! (IMG:style_emoticons/default/smilie_pokal.gif)
newdeal2 |
Dec 7 2004, 01:54 PM
Unregistered |
Oh, by the way...thanks to all of you. I couldn't have done it with out this club!
If I had to do it again I would bump up the the bore. For now I went with flat tops and a Jake Raby cam. Hope it all stays together. It revs strong! A monster compared to the tired old one I had in it from the PO. I imagine it will pull a lot stronger too (IMG:style_emoticons/default/biggrin.gif) |
newdeal2 |
Dec 7 2004, 01:56 PM
Unregistered |
Pics on the way...just charging the batteries.
Demick |
Dec 7 2004, 02:22 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Change oil now, and then again at 500 miles.
Congratulations! Demick |
newdeal2 |
Dec 7 2004, 02:23 PM
Unregistered |
Just checked the compression...130+ on all 4
Plugs are OK...a little rich but that's OK |
Lo-Fi Version | Time is now: 31st May 2024 - 11:32 PM |
