Factory Fog Light Help Needed |
saigon71 |
Aug 6 2013, 04:04 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
It wasn't that long ago I pulled these things off, but I can't figure out a couple of things on them. After struggling for a few hours on these, I decided to ask the world. First, the mounts are slightly offset from the center of the housing...how do I know which is left and which is right?
Secondly, I have 8 spring clips laying on the work bench & can't figure out where they go and what they hold: |
ezbngreen914 |
Aug 6 2013, 04:14 PM
Member Group: Members Posts: 441 Joined: 11-December 10 From: Sautee, GA Member No.: 12,472 Region Association: South East States |
green914 |
Aug 6 2013, 06:53 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
I don't know if this will help you (IMG:style_emoticons/default/blink.gif) these are pictures I took of a fog lamp as it was taken apart.
Attached thumbnail(s) |
green914 |
Aug 6 2013, 06:54 PM
In the reverse order.
green914 |
Aug 6 2013, 06:56 PM
I think you can see where the clips go in this pic.
green914 |
Aug 6 2013, 06:58 PM
(IMG:style_emoticons/default/smile.gif) This is split open just after removing the screw at base of the lamp.
Mikey914 |
Aug 6 2013, 07:00 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The only thing you are missing is the rubber seal around the glass. You may have this on yours, but it is necessary to keep water out.
green914 |
Aug 6 2013, 07:05 PM
When it goes back together it is important to have the bulb receptacle lined up with the bottom of the bulb pointing at the square-cut-out on the back of the front cover.
Katmanken |
Aug 6 2013, 07:18 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Where do you get the wire clips? About half of mine disintegrated into rust chunks and the rest are really pitted.
Jeffs9146 |
Aug 6 2013, 10:23 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
saigon71 |
Aug 10 2013, 05:40 PM
Thanks for the responses. The pictures were a huge help! (IMG:style_emoticons/default/beerchug.gif) I would highly recommend safety glasses when putting these clips back in. One of the clips got lost during installation, never to be found again, so one fog light is held in with three of them. Put the fog lights back on with new gaskets from 914rubber:
Lo-Fi Version | Time is now: 3rd June 2024 - 01:15 AM |
