tires, lbs |
tires, lbs |
cpavlenko |
Aug 8 2013, 04:02 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I got P 195 60R 15 tires, should I inflate tires to what it says in the trunk, or does anyone know what I should run on the fronts and the backs? (IMG:style_emoticons/default/confused24.gif) the sticker in the front trunk says 155 SR 15, 23 psi front and the rears 26 psi
Mike Bellis |
Aug 8 2013, 08:49 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Tire design has changed since that sticker was installed. It most likely is useless. pressurize them for road feel and handling.
I run my 245/45/16 at 35 psi of nitrogen. That is +/- the sweet spot for my setup. |
cwpeden |
Aug 8 2013, 11:36 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Falken RT615 , 205 50 15 - 32fr 34r
Falken ZE912 , 205 60 15 - 38fr 40r Pirrelli P4, 205 60 15 - 38fr 38r First two are on my 73 2.0 with koni sports and sways and 200 lb springs (rear sway disconnected) Third is on 72 with no sways and stock susp. Depends on your set up and how you drive it. RT615's for sport, ZE912's for highway |
solex |
Aug 9 2013, 02:00 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Use the pressure rating stated on the car. Check the web for discussions on tire inflation pressures.
Nitrogen eliminates water contamination as it must be delivered dry. |
bandjoey |
Aug 9 2013, 03:18 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
More from the street cars please. Low to mid 30's seems a little high.
For a better street ride wouldn't u want a lower pressure? 195x65 I use 26/29 per the gas tank sticker. Ride is good and no tire wear as in underinflated. About 30 k miles at this pressure. |
TheCabinetmaker |
Aug 9 2013, 03:34 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Your sticker says 23 front? All mine say 26. I start at 28 all around then test drive and adjust up or down 1 lb at a time till I get the best "feel". Lots of variables. tire choice, spring rates, swaybars, driving style, surface and surface condition, weight of driver, and even from car to car.
cwpeden |
Aug 11 2013, 12:42 PM
Wow, I didn't think I was that far off. When ever I lower the pressure of my street tires that low they feel way too 'squishy'. Of course they don't get enough miles to say its causing them to wear uneven.
Just went out and re-checked my pressures. Falken ze912's are 35f - 36r |
porschefile2010 |
Aug 11 2013, 09:35 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
Because the cars are so light I think the tyres need less rather than more pressure. Having said that I run mine at about 30-32, same front and rear. If you have too little pressure you will get incorrect wear on the edges of the tyres and if you have too much you will bulge the tyres and get wear up the middle because the sides of the tread aren't in contact with the road as the designers intended. So seems it's pretty much a case of what is right for the particular tyre you choose and keeping the tread properly planted on the road.
Lo-Fi Version | Time is now: 3rd June 2024 - 05:42 AM |
