monkeyboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None ![]() |
I have access to a set of slightly used Wilwood Dynalite calipers.
What would I need to do to bolt them up in the front if I have a set of 914 struts? Would I need to convert to 911? If they would what rears could I run if I wanted to keep an emergency brake, and what master would they work well with? They look like these: Wilwood |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
nobody asks about bigger brakes unless their car does not stop well.
when is the last time your stock calipers have been rebuilt and your system bleed? you running wide or narrow tires? jim |
monkeyboy |
There is nothing wrong with my brakes. Got everything rebuilt from Eric a couple of years ago.
My dad is going from 4 piston calipers to 6. I can take his cast offs if I want them. That's why I'm asking. I have access to free brakes! |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
There is nothing wrong with my brakes. Got everything rebuilt from Eric a couple of years ago. Not trying to b a smartass, but this sounds like creating a solution for a problem that doesn't exist (IMG:style_emoticons/default/confused24.gif) |
monkeyboy |
Probably, but that's why I'm asking first. It was on my miind since I was getting ready to order the new calipers for dad.
Lo-Fi Version | Time is now: 3rd July 2025 - 08:43 PM |
