power for add on gauges, this is actually for my vw |
Mike D. |
Aug 10 2013, 12:49 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
since I've added the type 4 engine to my vw fastback I want to add some 914 gauges. Can I use always on power for the gauge power? I'm adding a tachometer, oil pressure gauge, oil temperature gauge.
sportlicherFahrer |
Aug 10 2013, 01:54 PM
Nothing to see here. Group: Members Posts: 1,088 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
If you use a constant power source you will most likely just drain your battery. Should be able to use a test light and see what fuses have key on power and branch off of one of those, and/or try for a relay method so the draw on the fuse is only to drive the relay and not the gauges.
mrholland2 |
Aug 10 2013, 04:28 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Do you mean ALWAYS on? Or always on when the ignition is on? The answer to the first is no, the answer to the second is yes.
since I've added the type 4 engine to my vw fastback I want to add some 914 gauges. Can I use always on power for the gauge power? I'm adding a tachometer, oil pressure gauge, oil temperature gauge. |
Mike D. |
Aug 10 2013, 09:36 PM
I pretty much knew the answer. But I had perfectly good clock power sitting there and no more room in the fuse box. I made room and have switched on power.
Thanks |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:04 AM |
