> Clutch cable won't hold adjustment
KELTY360
post Aug 11 2013, 07:38 AM
914 Neferati
I've had the car 7 years and usually have to adjust the cable about every 6 months to restore complete engagement and smooth shifting, most notably in first or reverse. Now, I can adjust as usual and it works fine, but only for a few miles when it won't fully disengage and becomes very difficult to get into first or reverse without grinding.
A new cable was installed 3 years ago and has worked fine til now. Is it just stretching out and needs replacement or could there be something more sinister going on?
Replies(1 - 8)
Millerwelds
post Aug 11 2013, 07:42 AM
Pleepleus
Do you have it secured with two nuts locked together so the adjustment is not changing?
KELTY360
post Aug 11 2013, 07:49 AM
914 Neferati
QUOTE(Millerwelds @ Aug 11 2013, 06:42 AM) *
Yes, it is securely double nutted.
JoeSharp
post Aug 11 2013, 07:54 AM
In Irvine, Ca. May 15-18
It's gone. Replace it before it leves you stranded and shows you where the strands are.
post Aug 11 2013, 08:12 AM
(IMG:style_emoticons/default/agree.gif) That or a spot weld on the clutch tube has failed.
Spoke
post Aug 11 2013, 08:16 AM
Jerry
I had the same problem on both of my 914s.
The first one kept needing adjustment until I noticed the clutch tube moving toward the interior of the car. The tube attachment at the firewall had rusted.
On the other 914, a few adjustments days apart preceded a big BANG when the clutch pedal when to the floor as the cable broke.
If the clutch tube is not rusted at the firewall, replace the cable before you drive it further.
KELTY360
post Aug 11 2013, 08:27 AM
914 Neferati
I haven't checked the tube. I'll do that.
KELTY360
post Aug 12 2013, 11:48 PM
914 Neferati
The tube checked out fine. Turns out the cable was frayed on the outer winding while the inner core was intact. Smooth clutch operation restored! (IMG:style_emoticons/default/cheer.gif)
Thanks to Greenie for helping out. In spite of what people say, he's not a bad guy.....don't tell him I said that. (IMG:style_emoticons/default/grouphug.gif)
tracks914
post Aug 13 2013, 10:24 AM
Canadian Member
QUOTE(76-914 @ Aug 11 2013, 06:12 AM) *
- Lo-Fi Version Time is now: 22nd September 2026 - 07:16 AM
