| 914itis |
Aug 12 2013, 11:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Will this fit a 914-6 at the stock location?
| SLITS |
Aug 12 2013, 11:12 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
NO
| ConeDodger |
Aug 12 2013, 11:14 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,410 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
911 tank?
| r_towle |
Aug 12 2013, 11:56 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
yes 911 tank.
I wonder, would it fit on the other side? rich |
| 914itis |
Aug 12 2013, 12:42 PM
Yeah 911SC
| brant |
Aug 12 2013, 12:56 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,179 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
only in a 911
| mepstein |
Aug 12 2013, 01:18 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,630 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Don't hack up the car. Do it with the right kind of tank
| 914itis |
Aug 12 2013, 01:25 PM
No, I will order one from them.
Thanks. |
| r_towle |
Aug 12 2013, 01:27 PM
| 914itis |
Aug 12 2013, 02:27 PM
I am not going to start until mid-winter anyway. By that time I will let you know on that offer. I still need to gather a few parts . Headers , mufflers, tin, motor mount and bell crank.
| worn |
Aug 12 2013, 03:19 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,563 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Will this fit a 914-6 at the stock location? I bought one too just to try. No, it won't fit, but it isn't a stupid idea because they have a lot of similarities. I ended up instead cutting up my old 911 tank in two to see how they baffle it for when I weld up a new tank for the 914. I would be doing it too if it weren't for all the body work that came along with the recipient car that has got in the way. One thing that has long puzzled me was why Porsche felt compelled to run the pressure line through the tank walls to get to the oil filter. In at the fitting and then back to the console and then through the filter. I am thinking of skipping that with my design and buying a filter stand from JEGs for around $25-30. |
| SLITS |
Aug 12 2013, 03:58 PM
The only one I have seen with a 911 tank everybody called a "bastard". It was cut into the rear trunk floor. 1/2 hung below the floor and 1/2 above.
The engine doesn't give a crap where it is as long as the the oil in the tank is above the flooded suction pump. |
| shoguneagle |
Aug 13 2013, 08:49 AM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Slits has it right. I do have a 911 tank and it is placed in the rear trunk. It looks ok but it is not right for the "914 follower". My reasoning was to match the oil capacity of the engine requirements plus front oil cooler. I built to handle the "warm" Arizona summers and it has done the job very well. I built a18 quart capacity which gives me plently of cooling during the summers, winters do not drive since I live in the "high country" and it is cold out there.
I could have used the Peterson type located in the front but I believe the oil has to as close to the engine as possible and level with the engine inlet. Sorry I did it? No! It satisfies my needs and does the job well. Not according well accepted and called a "bastard". I agree with this statement and would not do it on a normal 914. My car has been retrieved from the "junkyard" and I built it with available parts. I did have a sixes original oil tank but it just did not fit my needs. Way back, there were a series of local articles on converting the 911 tank to the 914 location. I do not remember exactly but the bottom of the tank had to be narrowed and something had to be done to the internals of the tank. Increased capacity in the original tank was also done by cutting the tank apart and putting a metal section; again, probably something had to be done to the internals of the tank. In sum, find a solution to your needs and build; be happy and enjoy. As an alternative for cleanliness, probably the Peterson tank is the best. Most people put it up front taking up valuable "real estate" in the front trunk. Food for thought. Steve |
| pcar916 |
Aug 13 2013, 09:11 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
If I were to run a tank in the front the return line would be a -20AN rather than the existing -16AN. Not for anyone on a strict budget! Then again... neither is this mod. (IMG:style_emoticons/default/beerchug.gif)
... and a properly engineered solution is the bomb regardless of the aesthetics, but execution is everything. My only issue with the stock -6 tank in the stock location is that the factory could have built-in more cooling capacity into that side of the car with some fins and a vent/scoop. But then that's why the Porsche family always liked owner-builders making proper mods. |
Lo-Fi Version | Time is now: 16th April 2026 - 01:43 AM |
