| Andyrew |
Aug 14 2013, 12:02 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Ive got a line on some calipers, and wondering if anyone can ID them.
Eric? Any idea on what they are worth? They are missing your standard hardware, but were rebuilt and coated. Attached image(s)
| Eric_Shea |
Aug 14 2013, 03:52 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hard to tell... piston size?
| Andyrew |
Aug 14 2013, 04:04 PM
Donno. Im thinking they are rears though. But they were built from ECS tuning for a big brake kit. Thats about all I know.
| Andyrew |
Aug 14 2013, 04:05 PM
I can pick them up for about $275, but I might be able to pick them up for cheaper...
| 0396 |
Aug 14 2013, 09:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Looks like my 993 Big Reds.
| jcd914 |
Aug 14 2013, 09:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You need measurements from each caliper, either they are mismatched or the cross over tube is installed incorrect on 1 of the calipers.
On 1 caliper the cross over tube is near the small pistons and on the other caliper the tube is near the large pistons. Does ECS use real Brembos or are they a copy? Jim |
| Andyrew |
Aug 15 2013, 07:46 AM
Looking at the mounting holes in relation to the piston size it looks like there is one left and one right. I they they just have the tubes and bleeders installed wrong.
| ChrisFoley |
Aug 15 2013, 08:28 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
They look more like S4 Fronts than Big Reds to me, but a little hard to tell.
The difference is the dimension of the pads. Top to bottom is the same but in/out dimension is larger on the big reds (48mm vs. 58mm). That is an excellent price btw. I use this chart found on the Pelican webserver to help with caliper identification. Brakes Identification Chart |
| jcd914 |
Aug 15 2013, 09:43 AM
they just have the tubes and bleeders installed wrong. Essentially that was what I was pointing out, although without measurements (pad size, piston diameters, etc...) from each caliper you don't know for sure if they match each other. I have a 'pair' of Ferrari (F40) calipers that turned out to be 1 front caliper and 1 rear. I also had to swap, side to side, a pair of Brembo calipers that the shop before me had installed wrong and I had to move the bleeders and cross over tubes. Would have been easy except the flair nuts on the cross over tubes had been epoxied in. Jim |
| Spoke |
Aug 15 2013, 10:52 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,432 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Here's a 930 rear caliper from an '86.
| Eric_Shea |
Aug 15 2013, 11:03 AM
Price is OK but, again, pistons size will tell the story. Rears will have smaller 30, 34 and possibly 36mm pistons.
The one on the left (in the last picture) is set-up properly. These calipers are generally cheaper because kits to rebuild them are as follows: Wiper seal = $32.50 Bore seal = $18.50 Total = $51.00 Now... times that by 4 because that's just one bore. Now, times that by 4 because that's just one caliper. So $204.00 per caliper to rebuild only... not restore (which is why a lot of these just get powdercoated). $816.00 in just kits to do one car... (IMG:style_emoticons/default/blink.gif) Hence why the market seems to be flooded with these at low prices. |
| ChrisFoley |
Aug 15 2013, 11:16 AM
I have a set (f&r) of unused, never installed, 993TT Big Reds available for $1800.
| Eric_Shea |
Aug 15 2013, 11:20 AM
That's a (very) good price for NOS Big Reds
| Andyrew |
Aug 15 2013, 09:13 PM
Chris, thanks for the info and comparison price. The guy literally said someone make me an offer or I throw them away, and has a price of 275obo..
Eric, I figured they would be really expensive to rebuild, he says they are rebuilt but I dont see any dust boots. Thanks for the pricing. He's going to get me the piston size soon and we'll go from there. I was thinking of putting these on my 914 or maybe my Allroad if I can do it cheap enough. Here is what the S4 and A6 (Allroad) calipers look like. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.audizine.com-172-1376622942.1.jpg) Thanks for the info guys (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 12th October 2026 - 05:53 PM |
