> Shift knob removal, Aftermarket knob won't come off
NFBrown
post Aug 15 2013, 10:44 AM
I just got a dandy new stock shift knob but I can't get the beat-up leather covered one off. Of couse I don't know how it's attached (just bought the car) but assuming it used a stock crush washer should it just pull off? I probably should get a new crush washer before I cut the knob off (IMG:style_emoticons/default/dry.gif)
Always wanted a 914, finally got one. Please help the newbe.
Nick
Replies(1 - 10)
76-914
post Aug 15 2013, 11:12 AM
My guess is that it was glued on because the PO didn't know about the crush washer.
stugray
post Aug 15 2013, 11:22 AM
To start with, I would put a crescent or open end under the knob & "tap" it with a hammer.
Dont go too gorilla on it or you might damage the shifter bushings down in the shifter mechanism.
Stu
Eric_Shea
post Aug 15 2013, 11:23 AM
PMB Performance
You would have to heat the shaft to 500 degrees with a torch and then use a proper open end wrench (16mm) and tap it up and off.
Rob-O
post Aug 15 2013, 11:57 AM
Post a pic of the leather covered one. Many had set screws that helped hold them on. It's a long shot, because I figure if you posted here then you've already looked it over pretty good and would've seen the set screw. Also because the set screw usually doesn't hold them on very well (you can still pull them off by hand), hence a lot of guys using the glue!
luskesq
post Aug 15 2013, 11:59 AM
Before you go hammering on stuff, make sure there isn't a small set screw at the base of the knob (it may not be in plain sight). I have a leather one without crush ring but a set screw.
Keith
rick 918-S
post Aug 15 2013, 03:11 PM
Hey nice rack! -Celette
I have one that has a threaded collar at the base that hides allen set screws. Post a photo before you wreck something.
VaccaRabite
post Aug 15 2013, 03:33 PM
En Garde!
Agree with everyone else.
Check for the set screw! That is a really common way to attach aftermarket knobs.
r_towle
post Aug 15 2013, 04:38 PM
Custom Member
just use a sawzall and shorten the shaft...its too long anyways (IMG:style_emoticons/default/smile.gif)
NFBrown
post Aug 15 2013, 06:01 PM
It "was" glued on. It's in pieces now. The new knob is installed with some tape to build up the shaft until I can get a crush washer. The car needs so many little things that at some point I'll just have to stop and order.
Thanks for the ideas ( except maybe the Sawzall ).
Nick
VaccaRabite
post Aug 15 2013, 06:08 PM
En Garde!
You can use paper or felt (better) instead of a crush ring. Don't use tape. It gets gummy in very short time.
Cut 2 pieces of felt about the width of the diameter of the shift rod and 2 inches long. Lay them over the top of the rod so they form and "X". But the knob down over the top. It will be tight, its supposed to be. You can't see the felt, but it will hold the knob securely for years.
Zach
- Lo-Fi Version Time is now: 16th April 2026 - 05:04 PM
