Difference between early and late 911 parts for rear brake conversion |
chad newton |
Aug 15 2013, 06:14 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
I was wondering what difference there is between 911 rear end parts and why guys only talk about pre 74. Will they all fit on a 914? I am still planning at the moment to bolt these parts to a 901 trans. All I will need I am assuming is the early coarsed spline axle shafts and all years of 911 parts will fit. Right???
ChrisFoley |
Aug 16 2013, 06:53 AM
I am Tangerine Racing Group: Members Posts: 7,936 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I was wondering what difference there is between 911 rear end parts and why guys only talk about pre 74. Will they all fit on a 914? The later tophats which support the ebrake components are 5mm taller, which affects the alignment on a 914 trailing arm. You either need to shim the later tophats or the shoes will hang out of the rotor a little bit. |
Lo-Fi Version | Time is now: 13th June 2024 - 09:26 PM |
