QUOTE(chad newton @ Aug 15 2013, 07:14 PM)
I was wondering what difference there is between 911 rear end parts and why guys only talk about pre 74. Will they all fit on a 914?
The later tophats which support the ebrake components are 5mm taller, which affects the alignment on a 914 trailing arm. You either need to shim the later tophats or the shoes will hang out of the rotor a little bit.
