Tilly74 |
Member ![]() ![]() Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None ![]() |
Anyone ever put a larger displacement motorcycle engine in a 914? The VMax features a compact v-4 that makes 197bhp, 123 lb/ft torque and will peel your face off. Obviously it weights a lot less, but then I got to thinking about other options. (IMG:style_emoticons/default/idea.gif) We just got a Triumph Rocket III in stock and it's a 2.3 litre inline 3 cylinder. Makes 146 bhp and 163 lb/ft torque. Both motors are pretty compact and feature a shaft drive 6-speed transmission.
I think the transmission mating would be the most difficult, but what about adapting the motorcycle transmission somehow? I picture connecting the drive shaft to a rear differential of some sort. Or...if you could mate the shaft drive from the bike somehow to the 901, you could essentially have 30 different gearing combinations. All I would do is mount a hand clutch somewhere, maybe near where the rear brake is, and replace the heater lever with a simple hand shifter that would link to the bike's transmission. You could ALWAYS have the right gear, but you might need an extra hand or two, or a co-driver to manage the second transmission lol. One major benefit would be the lighter weight and the smaller radiator size, which might be able to be placed in a wheel well or somewhere besides the front trunk. This sounds crazy and over engineered to me, and probably not worth the effort, but I'm 27 and I'll hopefully be involved with teeners for the next 73 years (assuming I make it to 100, which is my goal), so I've got plenty of time to become a car building pioneer lol. Feel free to poke as many holes in this plan as you like. Won't hurt my feelings a bit. ![]() ![]() |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
Lots of Lotus 7 type cars use motorcycle engines...
-Steve |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Motorcycles converted into trikes are using IRS rear ends now, that may be something to look into...
Tilly74 |
02loftsmoor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region ![]() ![]() |
WOW that looks like a lot of work.. and not much Room (IMG:style_emoticons/default/sawzall-smiley.gif)
Tilly74 |
BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
GSXR 1000 powered fiat X1/9
http://www.youtube.com/watch?v=cQM3krBmqbg I'm building one this winter .... (IMG:style_emoticons/default/biggrin.gif) The x19 is smaller & lighter than a 914. Mass has a lot to do with the survivability of the bike gearbox in a car. (the GSXR 1000 and hayabusa seem to have gearboxes that hold up a bit better than the R1 and CBR's) ![]() ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
The engines typically have very little low end torque, which makes them difficult to drive, the transmissions have no reverse gear, and they rip your face off because they are in a much much much lighter vehicle. The owners of bike engined lotus 7 based cars even comment that the engines dont have that much torque for that 1300lb car... Add another 800lbs and your looking at an even worse situation.
Your much better off with a car based build. |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
The engines typically have very little low end torque, which makes them difficult to drive, the transmissions have no reverse gear, and they rip your face off because they are in a much much much lighter vehicle. The owners of bike engined lotus 7 based cars even comment that the engines dont have that much torque for that 1300lb car... Add another 800lbs and your looking at an even worse situation. Your much better off with a car based build. Exactly right. I have a Seven replica as well as motorcycles so know both, and there's no way in hell I'd put a V-Max or any other moto engine into a 914. Even the Seven replica is 1150 lbs with engine and transmission. You could get that down to 900 lbs with a motorcycle engine/transmission, maybe less, but you'd still be down torque. I saw a rear-engine Mini conversion in the U.K., an almost all plastic car with a Hayabusa motor in the back that probably weighed 800 lbs. That would work. If you can get your 914 down to 800 lbs that would work too, but good luck with that, and even so it wouldn't last long pushing that much weight around. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Why do people fail to realize the weight difference between a bike and a car and how that might matter? Do we have to explain it?
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,294 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Ahem....Goldwing! 1800cc flat 6 118hp / 167 tq (stock), Fuel injected, sequential 5 speed with reverse gear on a vehicle that tips close to 900lbs.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,010 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
What does the fiat weigh? I've always heard they were heavy. I see that one is a racecar. A teener racecar can be 1600 with a -4.
What does that one weigh? |
BKLA |
What does the fiat weigh? I've always heard they were heavy. I see that one is a racecar. A teener racecar can be 1600 with a -4. What does that one weigh? I haven't weighed it yet but it is very light. My son and I easily pushed it up on the ramp trailer. Every panel is 'glass except for the door skins. The car currently has about 50lbs of lead bolted into the passenger footwell from when it ran GP. I'd hazzard a guess that it is about 1000# without the motor/gearbox/axles... |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
I say put TWO V-Max engines in there and hang on. (IMG:style_emoticons/default/driving.gif)
brant |
What does the fiat weigh? I've always heard they were heavy. I see that one is a racecar. A teener racecar can be 1600 with a -4. What does that one weigh? I haven't weighed it yet but it is very light. My son and I easily pushed it up on the ramp trailer. Every panel is 'glass except for the door skins. The car currently has about 50lbs of lead bolted into the passenger footwell from when it ran GP. I'd hazzard a guess that it is about 1000# without the motor/gearbox/axles... awesome... I googled and found various stock weights from 2015 to 2130 so about the same... maybe slightly lighter than a teener depending upon year PCA club racing accepts the stock weight of early bumpered cars at 2149 in street trim |
Tilly74 |
I'm very aware of the weight difference between a car and a bike. My 914 came with a 67 hp, 99 lb/ft bus motor and I had a blast driving it. So I guess my question is: Other than flywheel weight, does it matter where the motor comes from? If a motor makes a certain amount of torque and hp, does it matter if its a type 4 or from a Yamaha? I've seen lots of money thrown into a type 4 that has a lot less than 200hp and 130lb/ft torque.
I do understand that a 914 wouldn't be the best choice for a motorcycle engine swap. Most motorcycle engines make 0 power below 5k, but some of these motors are different. The rocket III starts making power at 1200 rpm or something like that.. |
brant |
I would expect the strength of the gears to be vastly different. Made light to pull 900lbs to high rpm but not made to pull the weight of a car.
For example how would a 901 do under a Mack truck? |
Tilly74 |
I would expect the strength of the gears to be vastly different. Made light to pull 900lbs to high rpm but not made to pull the weight of a car. For example how would a 901 do under a Mack truck? That's a good point, I'm pretty sure I'll end up doing a suby swap eventually anyway, I just couldn't stop thinking about that bike ride lol. I should NEVER ride in a 914-6, but I don't think I would be capable of turning a ride down lol. |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
google the busa Miata....
the use the gear reduction in the tranny case 2/1 and gain the torque. it's being done. |
messix |
Lo-Fi Version | Time is now: 6th July 2025 - 10:22 AM |
