19mm MC with 17mm MC sensor?, Make the blinking stop... |
ezbngreen914 |
Aug 25 2013, 11:10 AM
Member Group: Members Posts: 441 Joined: 11-December 10 From: Sautee, GA Member No.: 12,472 Region Association: South East States |
I have a 19mm Master Cylinder on my car but I believe that the mechanic reused the sensor switch from the leaking 17mm MC that it replaced. The warning light has been blinking. The light was not blinking with the small leak that I had with the 17mm. I'm hoping that the sensor switch just needs to be reset.
How do I reset the 17mm? Does the 17mm switch work with the 19mm MC? Thanks as always! |
Steve |
Aug 25 2013, 01:17 PM
914 Guru Group: Members Posts: 5,609 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Did you reach in there and push the button on the sensor? It should be under the rubber black nipple.
ezbngreen914 |
Aug 25 2013, 01:48 PM
Steve |
Aug 25 2013, 02:03 PM
I have a 19mm master cylinder and the button is inside the black rubber cover. I just push down on the rubber cover to reset it. Can't remember what the 17mm looks like. It's been to long since the switchover.
McMark |
Aug 25 2013, 08:53 PM
The unit with a single connection has a reset switch. The two connection unit doesn't. You can pull the switch without affecting the brake bleed (always use caution the first time out though, your e-brake works, right?). Pull out and manually operate the switch to make sure it works. If it does, look inside where it goes, there is a little plunger that moves forward-backward. Make sure the thin section is in the middle. If it's not, use something small (a punch?) to move the plunger back into place and reinstall the switch.
ezbngreen914 |
Aug 25 2013, 09:56 PM
The unit with a single connection has a reset switch. The two connection unit doesn't. You can pull the switch without affecting the brake bleed (always use caution the first time out though, your e-brake works, right?). Pull out and manually operate the switch to make sure it works. If it does, look inside where it goes, there is a little plunger that moves forward-backward. Make sure the thin section is in the middle. If it's not, use something small (a punch?) to move the plunger back into place and reinstall the switch. Thank you sir, I'll give it a try! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 07:51 AM |
