Rear trunk hinge bracket, Bracket popped it's welds |
LotusJoe |
Aug 26 2013, 02:02 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I seem to recall someone was selling a replacement bracket that either bolted on or riveted?? Or am I dreaming? (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-11085-1377547364.1.jpg) |
Eric_Shea |
Aug 26 2013, 02:04 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Weld it...
dlee6204 |
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
JawjaPorsche |
Aug 26 2013, 02:05 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
76-914 |
Aug 26 2013, 02:09 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Pete @ Restoration/Design. Which welds? If bolt welds came loose replace it. If bracket welds came loose I'd still order a new one but I'd look at the wall it is welded to pretty carefully.
LotusJoe |
Aug 26 2013, 02:14 PM
Thank you, that's the kit I was looking for, however at $80.00 I think I'll just weld it back.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.jwesteng.com-11085-1377548077.1.jpg) |
green914 |
Aug 26 2013, 02:58 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
Thank you, that's the kit I was looking for, however at $80.00 I think I'll just weld it back. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.jwesteng.com-11085-1377548077.1.jpg) (IMG:style_emoticons/default/agree.gif) weld it back. |
pt_700 |
Aug 26 2013, 04:03 PM
Senior Member Group: Members Posts: 1,093 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
a local muffler shop welded a used replacement bracket in for me.
of more difficulty was re-setting the torsion bars... i think i invented a few new curse words... |
Bartlett 914 |
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Weld it on. There is a lot of pressure on this part. The problem is the lubrication for the hinge bolt. There is no easy way to lubricate it. They have a tendency to seize which rotates the bracket breaking it off. Same for the front trunk. Grease it when installing
SLITS |
Aug 26 2013, 04:23 PM
Which is exactly why I ditch the torsion bar setup and go to a gas shock set up to relieve the pressure the torsion bars put on the bracket.
BKLA |
Aug 26 2013, 10:22 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
I have an unused jwest hinge kit I'll sell for $50.00 shipped.
I got rid of the torson spring, installed the gas struts and welded the stock hinge point back on. But I had the engine out and rear suspension off to make the repair much more simplifed. |
Lo-Fi Version | Time is now: 4th June 2024 - 02:46 PM |
