1973 Horn blows when turning steering wheel |
HalfMoon |
Aug 26 2013, 09:58 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I'm sure the anwser is simple but I've yet to figure it out.
Momo wheel and horn button. |
Mike Bellis |
Aug 26 2013, 10:11 PM
Just stop turning and you'll be fine... (IMG:style_emoticons/default/biggrin.gif)
The wire coming from the ring triggers the horn when grounded. You either have an intermittent short or an intermittent open depending on how you wired it. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
moldygreg |
Aug 26 2013, 10:33 PM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
Doing this from memory. Is the horn contact ring well 'nested' within the momo adapter? I don't think the momo adapter and horn contact screw holes always line up perfectly; you may need to chip away some of the plastic horn contact ring with a small blade to allow the holes to line up and 'snug into' the adapter. I think some people have actually drilled new holes in their contact ring. Did you over-torque the steering wheel? Should be 40lbs. |
eg914 |
Aug 26 2013, 10:45 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
The brass on the contact ring can wear, break, and make contact when you turn. Pull the steering wheel and check the contact ring.
Sleepin |
Aug 27 2013, 08:09 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Make sure the wire doesn't have a crack in the insulation.
r_towle |
Aug 27 2013, 12:08 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
remove fuse.
If you need to honk, its too late, or your just being an asshole. rich |
Lo-Fi Version | Time is now: 6th June 2024 - 07:05 AM |
