The new adventures of Sweet Pea, new caretaker |
x-faktory |
Aug 27 2013, 09:20 AM
Newbie Group: Members Posts: 21 Joined: 16-August 13 From: PNW Member No.: 16,261 Region Association: Pacific Northwest |
Where is Sweet Pea now? After searching for a while and looking at many lesser cars, I could not get this fine 914 out of my mind. I contacted Joel, we struck a deal and Melisa and I jumped on a plane for San diego to pick up Sweet Pea. We met with Joel & Shannon, inspected the 914, had a great dinner with new friends, exchanged the paperwork and headed back to the hotel. Next morning, Joel & Shannon delivered our new 914 to the hotel and we headed north.
This 914 runs very strong. Some front end vibrations at 70-75, but otherwise...solid and gets lots of attention wherever it goes. I am a happy camper! I've attached a couple pix. Joel & Shannon in tears...Melisa and I smiling durng the hand off. And then................a pic of our first stop. Can you guess where Sweet Pea is...or at least was yesterday? regards, Al PS: Joel & Shannon are the bomb. Attached image(s) |
McMark |
Aug 27 2013, 09:22 AM
NORD |
Aug 27 2013, 09:26 AM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
x-faktory |
Aug 27 2013, 09:44 AM
nord,
I'm in mount Vernon.............not too far from you. regards, al |
CptTripps |
Aug 27 2013, 10:48 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Cool story!
Glad to see happy new 914 owers. Congrats! |
KELTY360 |
Aug 27 2013, 11:38 AM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Isn't that Jerry Mahoney's old car? Looks like it's come full circle back to the PNW. Great car!
(IMG:style_emoticons/default/welcome.png) |
Drums66 |
Aug 27 2013, 11:43 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....Good to hear a positive "experience"
good fortune with her in the future! (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif)(WELCOME) |
x-faktory |
Aug 27 2013, 06:07 PM
Isn't that Jerry Mahoney's old car? Looks like it's come full circle back to the PNW. Great car! (IMG:style_emoticons/default/welcome.png) Yes, I believe that is correct. Coming back home. regards, Al |
messix |
Aug 27 2013, 06:09 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
if that's Jerry's old car then that is one very nice clean car.
I saw it over at kelty's house one day and drooled all over it! (IMG:style_emoticons/default/drooley.gif) |
x-faktory |
Aug 27 2013, 06:13 PM
Where is Sweet pea today?....at least as of last night and this morning
regards, Al Attached image(s) |
sixnotfour |
Aug 27 2013, 06:15 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Sweet..!!!!needs a six..
x-faktory |
Aug 30 2013, 08:57 PM
After my San Diego to Santa Barbara to Los Gatos to Redding to Eugene, OR to Mount vernon, Wa..............my new 914 is safe & sound in my garage.
Attached image(s) |
3d914 |
Aug 30 2013, 09:16 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Nice looking car!
Enjoy! |
messix |
Aug 30 2013, 09:39 PM
the picture really don't do the car justice!
Jerry is a body guy that does very nice work and that car is a great example of his skill! |
scott_in_nh |
Aug 31 2013, 09:27 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
What size wheels and tires?
Springs, shocks, bars? I love the way she sits - beautiful car! |
x-faktory |
Aug 31 2013, 10:04 AM
Here's the specs...from the P.O.
regards, Al 1970 914 Willow Green Suspension brakes wheel specs: Front suspension and brakes: 911 T Front suspension torsion bars: 18mm 911 type, stock red Front suspension sway bar: 914/4 type 15mm stock Front suspension bushings: stock rubber Front suspension strut inserts: Bilstein sport yellow new Rear suspension springs: 100 lbs Weltmeister SP100 black Rear suspension shocks: Bilstein sport yellow new Rear suspension sway bar: none Rear suspension bushings: stock rubber Wheels: Fuchs 16 x 6 polished lip, satin black center Tires: BF Goodrich 205/ 50 R16 Master cylinder: ATE 19mm, new Brake lines: ATE rubber, new Engine and drive train specs Pistons: 96mm flat top 8.5 to 1 compression Crank shaft: 2.0 Porsche 71mm Connecting rods: 2.0 Porsche Cam shaft: webcam XXX custom grind Cylinder heads: 2.0 Porsche 3 stud, rebuilt Induction: New dual Weber 40 IDF carburetors, center pull linkage heim joints, Teflon lined Terry cable Ignition: Bosch mechanical advance distributor with electronic trigger, Bosch blue coil BERU spark plug wires Exhaust: SSI stainless steel heat exchangers, Bursch merged tuned 4-2-2-1 collector Engine case: 1.5 quart low profile external sump Fuel pump: front mounted Carter rotary type powered by factory fuel power circuit Fuel lines: BMW 8mm CA ethanol fuel rating Oil: Brad Penn 20-50 Transaxle: rebuilt 901 side shift conversion, new shift linkage and bushings, 90wt hypoid Valvoline VR-1 Rear transaxle mounts: upgraded 911 sport mounts Starter motor: upgraded IMI Hi Torque gear driven with high current external solenoid Interior specs Morph interior panels 914rubber.com seals by Mark whitesel pedal cluster by Bruce Stone Steering wheel: 3 spoke Dino Floor mats: Lloyds black with green 914 monogram Seats: black with custom cloth center inserts, adjustable passenger seat Seat belts: new retractable type Entertainment: new stereo and Baupunkt speakers with IPOD and MP3 player Door panels: custom 911 RS type Pedal cluster: rebuilt, zinc plated, powder coated, silica-bronze bushing kit Exterior, paint and body specs Color: original L63k Willow green monochrome paint scheme Side marker delete, antenna delete Fresh weather strips rubber, door seals, bumper tops, body gaskets New windshield |
Daiberl |
Aug 31 2013, 10:12 AM
Senior Member Group: Members Posts: 574 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
Beautiful car, Jerry Mahoney did a fantastic job, great that the car is back in the PNW!
- Juergen |
green914 |
Aug 31 2013, 10:44 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
(IMG:style_emoticons/default/welcome.png) Looks great!
jimkelly |
Aug 31 2013, 10:57 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
great example of a beautiful narrow body (IMG:style_emoticons/default/wub.gif)
Harpo |
Aug 31 2013, 11:00 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 07:13 PM |
