L-jet harness layout |
jmargush |
Aug 31 2013, 09:31 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Does anyone have any photos or diagrams of how the L-jet Fuel Inj harness is supposed to lay or route through the engine bay?
I Just put everything back together and some of the drop seem kind of tight and i am assuming I haven't laid it back in the same path it was. I have all the connector in the right place just some are a bit tight. |
Shindog1961 |
Aug 31 2013, 10:41 AM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
http://www.pelicanparts.com/914/Parts/Fuel...early_small.htm
Pelican Parts has a few diagrams, above is the electrical wiring for an early 914 fuel harness. Hope this helps. |
JeffBowlsby |
Aug 31 2013, 11:28 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
No layout diagram exists. Its pretty simple - routes between the ECU mount by the battey to where the other end connects at the relay board. Lays over and at the back of the engine bay. Nothing should be tight, if so, readjust to give slack to each branch and connection.
jmargush |
Aug 31 2013, 12:02 PM
No layout diagram exists. Its pretty simple - routes between the ECU mount by the battey to where the other end connects at the relay board. Lays over and at the back of the engine bay. Nothing should be tight, if so, readjust to give slack to each branch and connection. I tied it to the rear piece of tin maybe that pulled some of the slack out of the harness. |
Drums66 |
Aug 31 2013, 12:26 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....Allow(slack in wires) for the vibration of the motor (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:10 AM |
