Rear View Mirror Fell Off My 914, Is there a tab or insert in housing ? |
BVCSURF |
Dec 12 2004, 09:36 AM
Newbie Group: Members Posts: 3 Joined: 1-November 04 From: ROCKAWAY,NY. Member No.: 3,043 |
Hi Folks:
The mirror stem base has a small screw which I removed but it doesn't detach , nor does the center of the base that adheres to the window seem to have loosend up. Which part dos the screw hold in ? I'd appreciate any help. Thanks, Bob C. (NYC.) |
BarberDave |
Dec 12 2004, 10:56 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I had the same problem,damn thing always falling off. Usually in a little cold weather,i tryed 4 different kinds of glue . Finally got one of those mirrows on Evil Bay that hangs from the center visor mount. Cleaned the glue off the windshield and never a futher problem. Vision is much better also, both to the rear and to the front. Dave (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) |
jim912928 |
Dec 12 2004, 11:13 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
On mine, the little screw tightens the mirror to the base/slotted thing that glues to the windshield. If I loosen the screw then I can remove the mirror from the windshield by sliding it up towards the roof. Yours might just be stuck/gunked on..give it some light taps towards the roof. Look first to make sure yours is a 2-piece mirror though (mirror and attachement plate that slides into a groove at the base of the mirror).
ws91420 |
Dec 12 2004, 12:00 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
It depends on if you have an OE mirror or aftermarket one. Can you post a pic. The OE base is about 1.5" x 1.5" and there is a small screw up the post to the base. Be careful not to strip the threads or the head of the screw.
scottb |
Dec 12 2004, 02:47 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
or you can do what i did. buy an old bmw mirror and make your own center mount unit.
i bought an older 5 series mirror (if memory serves), dremeled off the mounting posts and center spring, used the visor center mount as a guide to create the new mounting holes and all done. took about an hour including a beer break. now i did remove the visors since i am tall enough that all they did was get in the way so if you want the visors, then my solution won't work. here is a link for the type of mirror i bought. it works great and if you are over 6 ft tall, then you don't need the visors anyway. ebay beemer mirror |
BVCSURF |
Dec 12 2004, 02:56 PM
Thanks for the help Guys:
This rear view is OE and the pyramid shaped base finaly came loose from the stem with repeated light tapping. I had thought there might be a base insert like the newer mirrors and did not want to break the stem by mistake ! It's glued back on the windshield and hopefully it'll stay there ! Thanks again, Bob C. (IMG:style_emoticons/default/smilie_pokal.gif) |
skline |
Dec 12 2004, 03:06 PM
It wont stay, they never do. The factory did something special that has not been replicated since. I tried glueing mine in about 3 times and it fell off everytime. I finally got the factory pad and superglued it in.
markb |
Dec 12 2004, 05:33 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I got smart. Took the car to a windsheild place & had them glue it. It won't come off now, even if I want it too.
ws91420 |
Dec 12 2004, 05:37 PM
Used rear view mirror adhesive from FLAPS. Trick is clean both areas well and put activator on both pieces. Use tape to hold base in place and wait at least 24 hrs before remounting mirror.
jim912928 |
Dec 12 2004, 05:40 PM
I did the same as ws914. However I couldn't get mine to stick with the instructions that said put like 2-3 drops on it. I basically covered the rearview mirror side with the adhesive and it stuck like you wouldn't believe. I knew I had enough when pressed on the windshield I didn't see any dry spots on the glass from the other side.
Lo-Fi Version | Time is now: 1st June 2024 - 10:11 AM |
