shuie |
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 ![]() |
I need to post a WTB for a couple of random small parts so I can get my clutch cable connected to the throwout bearing lever. I know I need the threaded bracket that attaches the cable to the lever. I also know I need the M10 bolt and a washer to secure the wheel/guide that the cable rides on. Is there anything else, any other brackets, etc, not shown in the pic below that I need? I cannot tell exactly what I need from PET and I just want to make sure I ask for the right stuff.
TIA (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-2075-1378166219.1.JPG) |
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
shuie |
Yeah, I just looked in PET again and the clevis has a 911 part number. Pelican has that part in stock. I'll double check my hardware stash for the nuts. Thanks again
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,911 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Try to locate a metal trunnion block, not the plastic one (shown above).
The nutz are an off the shelf item at OSH Hardware. I don't remember exactly what size, but they take an 11mm wrench. You may also need a flat washer or two, and a 1" ~ 1.5" spacer between the arm and the double nutz. |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
You also need the tab washer that locks the cable to the cable stop (before the pulley. Pelican also sells these.
shuie |
Does anyone have a picture of all of this stuff in place? I'm sure it would make more sense than what I am seeing in PET.
turk22 |
Treetop Flyer ![]() ![]() ![]() Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest ![]() |
Here's a Pic from Bob's thread, and a couple he sent me to show the banjo clip
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
part #:
911-423-205-03-M260 At pelican. Stu |
Harpo |
Any one know the P/N of that special washer in the last two photos. I can't find it in the PET and I lost mine
Edit - found it. 914-423-283-00 and pelican only has one left Thanks David |
shuie |
yep, 914-423-283-00-OEM. They had (2) when I ordered mine this morning.
as an FYI, the sleeve/boot at the pulley is 914-423-922-02-M260 Thanks again for the pics and info. This was pretty helpful. |
euro911 |
I don't think the PET diagram shows this, but in some applications, a spacer may be needed between the trunnion block and the two nuts (as mentioned earlier). This is even with brand new cables on two of my cars (IMG:style_emoticons/default/confused24.gif)
I run the cable as follows: Through the arm - trunnion block - flat washer - 1.25" spacer - flat washer - nut 1 & nut 2. |
Lo-Fi Version | Time is now: 15th July 2025 - 12:28 AM |
