Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Just finished the bugger.
Fired up 1st go around. Cold as crap outside so them 40 IDF's were spitting and sputtering for awhile. Richened up the idle mixture and ran like a champ. I will let it cool down and re-do the valves. |
Joe Ricard |
So if you don't know the details I put ths motor together for Rob Watson.
2.0L U.S. pistons and cylinders. Web 86a cam. New bearings through out whole motor. new valve guides valve job port matched intake and exhaust. New clutch. Only leak so far is that GD oil temp sender plate. Everytime I mess with those things it is like making a deal with the devil. |
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
First, I would like to thank Joe for agreeing to build this motor for me. He is a true nine-fourteen friend and someone dedicated to preserving the breed. I visited him yesterday, Saturday and helped in a very minor way with putting the motor back together. He wanted to fire the engine up when I was there, but I wasn't able to stay until it happened. Anyway, I flew back to Tampa, from NO, this afternoon, but Joe called this morning and left me a message that the motor was running. I called back and he fired it up again and I was able to hear this motor run for the first time in over 18 months. I now have to the pressure to finish the 'restoration' on the car as I'm plannig to pick the motor up next month. Hopefully by my birthday, in June, I'll be able to have the car running.
Again Joe, thanks... Now for the smiles.... (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/mueba.gif) BTW, here's a shot of the motor when I left it at Joe's on Saturday... Attached image(s) ![]() |
Joe Ricard |
So Rob, Gots to remind you again. Don't forget the cooling tin. Crank that welder up tonight. Fix the tin Rob, Send the tin!!!!!
Spent the remainder of Saturday 4 hours playing with Carb linkage. Finally got them to open and close at the same rate. Tried every linkage arm in all the boxes I collected. Finally ended up drilling a slotted hole where I could fine tune the mechanical advantage to even out. |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,200 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Rob,
Is this out of the red car? Paul |
Joe Ricard |
Yes Paul the engine came out of the red car. I also believe YOU are putting it back there. (IMG:style_emoticons/default/laugh.gif) At least providing some tech support. Depending on the size of the vehicle transporting it all back to Tampa will determine what can remain on the motor. If not I will have everything marked and scribed for re-assembly.
Lo-Fi Version | Time is now: 20th June 2024 - 02:40 PM |
