Pilot Bearing, Installation |
Rhodes71/914 |
Dec 12 2004, 04:04 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Can the pilot bearing be installed into the flywheel without a press. I do have a vise. Any good easy methods?
skline |
Dec 12 2004, 04:28 PM
I just tapped it in with a hammer on everyone I have done. It doesnt take much so dont pound on it like you are driving a nail. Just tap it in.
skline |
Dec 12 2004, 04:30 PM
In fact, I think I used a 1/2in deep socket on it. Works great. (IMG:style_emoticons/default/smash.gif)
Rhodes71/914 |
Dec 12 2004, 04:48 PM
Thanks Scott, that was my plan but I read or heard somewhere about using a press.
Joe Ricard |
Dec 12 2004, 04:54 PM
Just use a nut and bolt with some washers. Good as a press easy to keep it straight. Then graduate to a socket to get it recessed for the felt seal.
Rhodes71/914 |
Dec 12 2004, 06:55 PM
QUOTE Then graduate to a socket to get it recessed for the felt seal. When I took this fflywheel off there was no felt washer and the bearing was flush in the flywheel. If I recess it on the engine side of the flywheel, it will stick out on the other side of the flywheel. (IMG:style_emoticons/default/confused24.gif) |
McMark |
Dec 12 2004, 07:10 PM
From the factory manuals. 3.2 mm depth on the friction side.
Attached image(s) |
Joseph Mills |
Dec 12 2004, 07:14 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Maybe someone that knows for sure will answer, but as I recall, the felt went on after the pilot bearing is tapped in - which puts it on the outside of the engine.
McMark |
Dec 12 2004, 07:16 PM
The pilot bearing goes in the flywheel, not in the crank.
The felt washer goes on the friction surface side of the flywheel, underneath the six hole "washer" plate. |
Engman |
Dec 12 2004, 07:34 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
I used a block o' wood to tap it flush - then a socket to tap it in. Checked depth with a dail micrometer and tapped until it was there.
M |
DNHunt |
Dec 13 2004, 08:59 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
The pilot bearing does sit in the flywheel. It should be 3.2mm recessed to leave space for the felt washer. There is a spacer in the end of the crankshaft that prevents the pilot bearing from being installed to deeply.
Miy spacer was missing in the new crank and the only one I could find new was from Porsche in a warehouse in Germany. I finally made one from some pipe I had around. I don't recall the dimensions. It just took some measuring and fitting. If I remember it was a pilot bearing installed in the crank instead of the flywheel that ate SirAndy's input shaft seal. Dave |
Rhodes71/914 |
Dec 13 2004, 11:35 AM
Got it all sorted out last night. Flywheel is back on the engine.
Thanks everyone. |
Joe Ricard |
Dec 13 2004, 07:56 PM
BTW how many holes for bolts? I believe 5. Not 6 as some have indicated.
Rhodes71/914 |
Dec 13 2004, 09:03 PM
QUOTE BTW how many holes for bolts? I believe 5. Not 6 as some have indicated. 5 Attached image(s) |
McMark |
Dec 13 2004, 09:41 PM
I said six holes because there's one in the center. (IMG:style_emoticons/default/ohmy.gif)
(IMG:style_emoticons/default/biggrin.gif) |
Joe Ricard |
Dec 14 2004, 06:47 AM
Why not 7 counting the dowel hole?
McMark |
Dec 14 2004, 07:30 PM
Because I was talking about the six hole "washer" plate that doesn't have a hole for the alignment dowel. (IMG:style_emoticons/default/rolleyes.gif)
Sheesh! (IMG:style_emoticons/default/lol2.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:07 AM |
