Electric Fuel Pump, What's the circled part? |
Hine62 |
Sep 7 2013, 09:04 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I have an electric pump in my 914 that looks like this. What's the circled part in the pic below?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1279.photobucket.com-15000-1378609497.1.jpg) I'm not familiar with this type of pump. How do I tell what it is rated at and the psi adjustable? |
Kirmizi |
Sep 7 2013, 09:16 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Looks like a Facet and the circled item could be an inline filter.
AFAIK they're not adjustable. |
larryM |
Sep 7 2013, 11:05 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
Cap'n Krusty |
Sep 7 2013, 11:40 PM
They're cheap, noisy, and somewhat unreliable. Use a Pierberg, which doesn't need a regulator for carbs.
The Cap'n |
pilothyer |
Sep 7 2013, 11:50 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
They sound like a metal beaked woodpecker on a metal tree.
Hine62 |
Sep 8 2013, 06:40 AM
Thanks for the replies.
I recently put dual carbs on and I don't think this pump is putting out enough pressure. First I was going to replace the filters, but then I got thinking that I didn't know the exact pressure that this pump is putting out. The gauge I have only goes to 5psi. |
brant |
Sep 8 2013, 07:06 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
You only want 3 psi for carbs. So the gauge you have if fine for telling you if you have enough pressure. It sounds like you may need to add a regulator. Much above 4psi will push you needles and seats open causing your float levels to go high and your car to be rich. You need to regulate that pump down to 3psi
Hine62 |
Sep 8 2013, 09:49 AM
I meant the gauge starts at 5psi...
brant |
Sep 8 2013, 10:53 AM
Oops my mistake
Drums66 |
Sep 8 2013, 12:31 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....That is a facet electric pump & the circled part is an early
ford fuel filter!! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif)( I used thick rubber mounting gasket's to knock noise!....) Tat..Tat....Tat...(no problem) |
rhodyguy |
Sep 9 2013, 07:34 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you need a gauge that reads lower than 5psi. or switch to the pump the cap'n suggests. less connections means less chance of fuel leaks.
aircooledtechguy |
Sep 10 2013, 11:02 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I call those pumps "the midget with a machine gun" (IMG:style_emoticons/default/blink.gif)
I prefer the CB Performance Rotary pump (which is made by Carter. I've put around 100K+ miles on the one on my '66 VW Bus over the past 15 years. It's never let me down, is whisper quiet and is internally regulated. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:40 PM |
