Painting transaxle |
SKL1 |
Sep 8 2013, 06:02 PM
Senior Member Group: Members Posts: 1,607 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Want to refresh the transaxle. Have cleaned and cleaned the exterior but want to maybe paint it to make it look nearly new. Have seen various pix of trans painted with Eastwood paint but search wasn't helpful.
What have people used with decent results? |
t collins |
Sep 8 2013, 07:06 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I just went thru this a few days ago using Eastwood's Alumablast
Attached image(s) |
euro911 |
Sep 8 2013, 10:09 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Rustoleum, gloss gray enamel. Easy to clean.
Black is supposed to help shed heat better (IMG:style_emoticons/default/confused24.gif) |
timothy_nd28 |
Sep 8 2013, 10:14 PM
Hi temp ceramic engine rattle can spray paint is good. After the paint tacks up, throw it in the oven at 200 degrees for one hour.
PanelBilly |
Sep 8 2013, 10:23 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I painted mine gloss black with exterior polane paint (I maybe spelling it wrong). Its a Sherwin Williams 2 part paint. I think I should have gone with a silver
John1180 |
Sep 8 2013, 10:48 PM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
Krylon dull aluminum gives a great minimal finish that makes it easy to clean, for under five buck$!
maf914 |
Sep 9 2013, 06:41 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Besides cleaning off the heavy duty oil/dirt deposits, what should you do to prep the case for paint? The aluminum appears to be sort of porous and I would hate to see the paint peeling off after putting in the effort to apply it.
John1180 |
Sep 9 2013, 10:00 PM
Had mine media blasted.
Cap'n Krusty |
Sep 9 2013, 10:01 PM
Besides cleaning off the heavy duty oil/dirt deposits, what should you do to prep the case for paint? The aluminum appears to be sort of porous and I would hate to see the paint peeling off after putting in the effort to apply it. It's not aluminum, it's a magnesium alloy. The Cap'n |
worn |
Sep 10 2013, 09:41 AM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Want to refresh the transaxle. Have cleaned and cleaned the exterior but want to maybe paint it to make it look nearly new. Have seen various pix of trans painted with Eastwood paint but search wasn't helpful. What have people used with decent results? I used DP-40 epoxy covered with clear coat. The epoxy is tenacious and the magnesium was clean all around. Attached thumbnail(s) |
r_towle |
Sep 10 2013, 08:07 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Gold? Really?
914forme |
Sep 10 2013, 08:18 PM
Worn,
Nice looking engine. I have had issues in the past using brass fittings. Almost lost and engine due to the extension to get a VDO multiple oil pressure sensor way from the block. I now us a design by Draft 42 Design, that uses a hose and then a multi tapped adapter. its 8mm and has both 8mm and 1/4" ports. Just giving you a heads up, hopefully you'll have better success. |
Katmanken |
Sep 11 2013, 05:20 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Designed a bunch of magnesium parts in m past, and the guy from the magnesium institute recommended an acid "pickle" to keep the parts from corroding, The books that he sent also recommeded a zinc coating as being a sacrificial anode.
Zinc chromate paint is one choice but that material is on the "hazardous material" and hard to find. It's also a little "soft" so I used a thin layer of a Dupont 2 part self etching primer (516S- 615s?) that contained zinc and sets up very hard . Then a thin coat of wheel silver. |
914werke |
Sep 11 2013, 06:09 PM
"I got blisters on me fingers" Group: Members Posts: 10,142 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
It's not aluminum, it's a magnesium alloy. The Cap'n Really...? (IMG:style_emoticons/default/dry.gif) not so sure, (IMG:style_emoticons/default/idea.gif) if it is, its a special "non-flammable" magnesium, since Ive had one go through as intense a fire as you can imagine and while the fan shroud DID burn up completely the trans while discolored was still intact and after cleaning & resealing it is operating in another car. (IMG:style_emoticons/default/smash.gif) |
ThePaintedMan |
Sep 11 2013, 06:15 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Really...? (IMG:style_emoticons/default/dry.gif) not so sure, (IMG:style_emoticons/default/idea.gif) if it is, its a special "non-flammable" magnesium, since Ive had one go through as intense a fire as you can imagine and while the fan shroud DID burn up completely the trans while discolored was still intact and after cleaning & resealing it is operating in another car. (IMG:style_emoticons/default/smash.gif) Hence the term "alloy". (IMG:style_emoticons/default/biggrin.gif) |
Katmanken |
Sep 11 2013, 08:23 PM
It's not aluminum, it's a magnesium alloy. The Cap'n Really...? (IMG:style_emoticons/default/dry.gif) not so sure, (IMG:style_emoticons/default/idea.gif) if it is, its a special "non-flammable" magnesium, since Ive had one go through as intense a fire as you can imagine and while the fan shroud DID burn up completely the trans while discolored was still intact and after cleaning & resealing it is operating in another car. (IMG:style_emoticons/default/smash.gif) Really. Aluminum doesn't corrode (much) and magnesium does. Mag goes to an to ugly black color. |
914werke |
Sep 12 2013, 12:43 PM
Well wadd'a ya know....
Non-combustible magnesium alloys Adding 2% of calcium (Ca) by mass to magnesium alloy AM60 results in the non-combustible magnesium alloy AMCa602. The higher oxidation reactivity of Ca causes a coat of calcium oxide to form before Mg ignites. The ignition temperature of the alloy is elevated by 200-300K. Oxygen-free atmosphere is not necessary for machining operations. |
Dr Evil |
Sep 12 2013, 01:36 PM
Dont media blast unless you have the whole thing apart and can clean it out very well. It will get into your bearings.
Yes it is mag, any paint that keeps it sealed is fine. |
euro911 |
Sep 12 2013, 02:14 PM
I suggest that you DO NOT blast with glass bead. If any gets inside and stuck into a small nook or cranny somewhere, it WILL eventually work itself loose and into your lubrication. Unless you're 200% sure that you got it all out (goes for the engine case, heads, etc., too), glass bead WILL destroy internals very quickly. |
worn |
Sep 12 2013, 08:36 PM
Worn, Nice looking engine. I have had issues in the past using brass fittings. Almost lost and engine due to the extension to get a VDO multiple oil pressure sensor way from the block. I now us a design by Draft 42 Design, that uses a hose and then a multi tapped adapter. its 8mm and has both 8mm and 1/4" ports. Just giving you a heads up, hopefully you'll have better success. I have the hose, but haven't installed yet. Thanks for the warning. It will actually simplify things. Yes it is magnesium - the case is like a feather alone. Zinc chromate paint can be found at aircraft supplies. The Dr is right you know. Dirt and grease is better than nothing because magnesium has a horrible jones for oxygen. Goes dull within minutes after brushing clean. |
Lo-Fi Version | Time is now: 10th June 2024 - 04:05 PM |
