C/V joint boot clamps, Zip ties |
Harpo |
Sep 9 2013, 09:49 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good morning everyone. Is it OK to use zip ties instead of the metal band clamps to hold the boots in place on my C/V joints
I have the correct clamps but I don't have the tool to crimp them on Thanks David |
Jonathan Livesay |
Sep 9 2013, 10:18 AM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Sure as long as you can get them equally as tight as the clamps. (IMG:style_emoticons/default/dry.gif)
dangrouche |
Sep 9 2013, 10:21 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I have used a nail nipper to crimp those metal bands. I have used zip ties as well. I would periodically check on those zip ties since heat can make those thing brittle and it would fall off. I would worry less if the zip ties are 3M brand, not the china brand from Harbor Freight.
worn |
Sep 9 2013, 10:23 AM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I have used a nail nipper to crimp those metal bands. I have used zip ties as well. I would periodically check on those zip ties since heat can make those thing brittle and it would fall off. I would worry less if the zip ties are 3M brand, not the china brand from Harbor Freight. Why not use stainless steel zip ties here? |
malcolm2 |
Sep 9 2013, 10:56 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Why not use stainless steel zip ties here? I got some of those from O'Reilly Auto Parts and I just could not get it very tight. I went with the black zip tie. I saw several pictures on here and just did it. Sounds like a good tip to check periodically. If I ever find any clamps like in the haynes or climer manual, I'll buy them, but this should get me rolling. |
Harpo |
Sep 9 2013, 12:07 PM
I have never heard of a SS zip tie. Only SS hose clamps
stugray |
Sep 9 2013, 12:08 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I dont know how big they go, but the sprinkler system "crimp-rings" for poly tubing are about the same.
The tool for crimping those looks exactly like a set of tile pliers, just with dull edges |
r_towle |
Sep 9 2013, 02:18 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
shoguneagle |
Sep 10 2013, 07:30 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Take a couple of hose clamps that will fit around the CV joint and rubber; put the adjustment screws approximately opposite sides and tighten; these are the worm screw type; balance is approximately equal and does the job.
bigkensteele |
Sep 10 2013, 07:40 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Good morning everyone. Is it OK to use zip ties instead of the metal band clamps to hold the boots in place on my C/V joints I have the correct clamps but I don't have the tool to crimp them on Thanks David I also have a new set of boots and clamps and no tool. I was planning on using a wire cutter with a few layers of electrical tape on the sharp edges to insure that I don't cut the clamp. Plan B would be to buy a cheap wire cutter from HF and file the edges dull. |
914forme |
Sep 10 2013, 07:43 PM
I have used these in the past. And this tool, done!
Attached image(s) |
r_towle |
Sep 10 2013, 07:49 PM
Good morning everyone. Is it OK to use zip ties instead of the metal band clamps to hold the boots in place on my C/V joints I have the correct clamps but I don't have the tool to crimp them on Thanks David I also have a new set of boots and clamps and no tool. I was planning on using a wire cutter with a few layers of electrical tape on the sharp edges to insure that I don't cut the clamp. Plan B would be to buy a cheap wire cutter from HF and file the edges dull. You won't damage stainless steel with wire cutters. Just use them as is, it will be fine. I do it all the time with nail cutters or wire cutters. |
Cap'n Krusty |
Sep 10 2013, 07:51 PM
Are we talking about the big end, or the end on the axle. The new boots come crimped in the metal flange, and you really don't need the small ends to be clamped. If you have the outdated style boots, end cutters work fine as a clamping tool, albeit the leverage is poor and the effort high.
The Cap'n |
Lo-Fi Version | Time is now: 7th June 2024 - 11:13 AM |
