type 1 oil pump install question |
jmargush |
Sep 11 2013, 02:33 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
When installing a type 1 oil pump in the type 4 do you use 2 gaskets (one between pump and case and one between pump and cover) or is there just supposed to be one between the pump and case?
worn |
Sep 11 2013, 02:58 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
When installing a type 1 oil pump in the type 4 do you use 2 gaskets (one between pump and case and one between pump and cover) or is there just supposed to be one between the pump and case? I would use two, but others use permatex. The most important issues you may already know are alignment of the pump holes with the case holes. IME the pump needs to come away from the case a little with a spacer. Also the tang may need grinding to avoid cam gear interference. It needs to engage but not push hard. |
Shindog1961 |
Sep 11 2013, 05:23 PM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
Are you sure they are compatible?
Valy |
Sep 11 2013, 06:03 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
two gaskets and sealant.
You can print yours on a paperbag from the link in my signature. |
jmargush |
Sep 11 2013, 07:28 PM
Very cool thanks
did you use curil T or K2 as a sealant? what did you use a pump? I have a feeling the Schadek I got might be a tad on the small side. |
Valy |
Sep 12 2013, 02:51 PM
r_towle |
Sep 12 2013, 09:02 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Lo-Fi Version | Time is now: 9th June 2024 - 02:25 PM |
