DPD wiring woes, Need Relay wiring diagram (photo) |
nine9three |
Sep 13 2013, 01:54 PM
Member Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest |
I just recently replaced all of the hoses on the AC system and after replacing the wiring to the relay (above center console on interior evap) doesn't work. The bowlsby DPD diagram is different than mine (relay). Could some one provide a photo with captions on photo relating to where the wiring connections go from relay?
Thanks |
Mblizzard |
Sep 13 2013, 03:01 PM
I have a DPD in mine. While it works, I still find the wiring suspect. Can't trace it out tonight but I can snap some pictures quickly if that would help?
nine9three |
Sep 13 2013, 09:25 PM
Mblizzard |
Sep 15 2013, 05:25 AM
That would be great. Thanks. I have a DPD in mine. While it works, I still find the wiring suspect. Can't trace it out tonight but I can snap some pictures quickly if that would help? Sorry got distracted! Too much football. Will take them this morning. |
Mike Bellis |
Sep 15 2013, 08:02 AM
Mblizzard |
Sep 15 2013, 09:54 AM
Here is what I have but the wiring in my car should be considered suspect but it works.
nine9three |
Oct 2 2013, 01:49 PM
Mike,
Yikes, they are all the same color. Can you identify where the wires are coming from? The far right wire (near side) with yellow terminal end I believe goes to the ON/Off switch to the unit. The center two wires go to the fuse panel. Can you identify which terminals (1-12)? The bottom far end goes ?? and the top twisted pair?? My wires are different colors so this makes it much tougher. Thanks in advance |
nine9three |
Oct 2 2013, 01:52 PM
Mike I have the wiring diagram from this book (bowlsby) it is too small and very grainy to make out. And the relay appears to be different? |
Lo-Fi Version | Time is now: 10th June 2024 - 05:10 AM |
