engine tin removal |
ruddyboys |
Dec 15 2004, 01:55 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
There is no way to get the top engine tin off with the engine in and not bend it. Is there a way to modify it so it will. After storing for the winter, come spring I would like to take it off to see if some rodent hasn't made a nest between the jugs, again.
Mueller |
Dec 15 2004, 02:55 PM
on some /4 race cars, I've seen them cut access holes in the sheetmetal to make sparkplug changes faster/easier.....just cut and make it so that they screw back on with tabs or the like...
Spoke |
Dec 15 2004, 03:29 PM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I was able to remove the tin from the cylinders on the passenger side with little problem. The hardest part was removing the screws which had rusted. About 5 screws came out ok, the rest I had to drill out. Replaced the screws with hex head bolts.
While the tin was off, I adjusted the valves. Man was that easy to do without the tin. I kinda wish that the tins were designed so the portion over the valve covers was removable. Spoke. |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:47 AM |
