Help removing stuck jets |
computers4kids |
Sep 22 2013, 09:16 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
After installing my wideband, and confirming my belief that I was running rich, I decided to calibrate by Edelbrock 1409 600 cfm by changing the metering rods and jets.
The carb is about 4 years old, but the first jet I tried to unscrew only started to strip the brass jet's straight screwdriver slot. Googling the issue had suggestions like soaking in PB blaster and using an easyout, some even used heat. I wanted to hear what your thoughts are before I attempt one of the suggestions. Do easy outs come that small? Thanks Attached image(s) |
JRust |
Sep 22 2013, 09:21 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
You should upgrade to FI Mark. As a matter of fact. I know this guy with an LS1 motor with FI that is going to be up for sale soon (IMG:style_emoticons/default/idea.gif) . Seriously though best of luck with jets. I would think a little PB blaster would do the trick. The idea of using heat on a carb freaks me out a bit. I suppose you've got all the fuel out of it so it should be fine
ThePaintedMan |
Sep 23 2013, 08:23 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I would start by taking the carb off the engine, if you have not already. Autozone has a cheap EZ out set that goes to really small sizes, one of which should be the correct size for a jet.
If I recall on Edelbrocks the jets stand out of the casting enough that you might be able to just get a pair of vise-grips on them as well. Or you could dremel a new slot in it for a screwdriver, but this time use a small hammer and chisel and tap it counter-clockwise. Usually the shock of each tap is enough to break through the galvanic corrosion. Probably want to stay away from heat. (IMG:style_emoticons/default/blowup.gif) |
rhodyguy |
Sep 27 2013, 08:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
or just spring for a NEW carb. sorry. why fight with the damn thing?
r3dplanet |
Sep 27 2013, 12:38 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Um, because a new carb is $500? Seems a bit extreme to replace a carb just because of a stuck jet.
My Barracuda has a Thunder AVS 650 carburetor and I love it. Have you tried a few light taps with an impact screwdriver? Do you have an A/F gauge? What car is this for? Impossible to tune correctly without one in my sweet opinion after tuning Eddy/Carter carbs for many years. It's also a cautionary tale. Whoever installed those jets didn't need to gorilla them in like that. -m. update: I just out and popped the cover from my carb. Those jets are totally recessed, so I'm confusing things in my mind. Can you post a pic? |
rhodyguy |
Sep 27 2013, 02:13 PM
simple search shows the 1409 avail for under $400. interestingly, they're listed for marine use.
computers4kids |
Sep 27 2013, 06:05 PM
Thanks guys...
Carb is like new. A couple of sharp taps of screwdriver ground to fit snuggly in the slot with the base supported unlocked the jets. Waiting for my calibration kit to arrive and I'll be ready to experiment. Yes, I have a AEM wideband and vacuum gauge (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:35 PM |
