Machining adapters for Subaru to 914 axels? |
CptTripps |
Sep 23 2013, 08:35 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Is anyone machining flanges to adapt the output flanges from a Subaru 5MT to work with 914 axels?
I have a set of the Renegade high performance axles that I'd like to re-use if possible. These axels were $700 and are beefy as hell. I'd rather not re-buy something if I don't need to. Just wondering if it is as simple as having a set of "adaptors" made? |
BIGKAT_83 |
Sep 23 2013, 03:33 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Try these guys....Subarugears
they have the adapters and the locking sleeve. The locking sleeve is about $180 dollars shipped and the adapters are less than $500 now with the exchange rate. |
jimkelly |
Sep 23 2013, 03:39 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I believe you don't need flanges - you need to have your 914 axles machined to accept a suby cv joint at the suby trans.
there are several different suby cv joints, so be sure what you are gonna use. http://www.dutchmanaxles.com/services |
d914 |
Sep 23 2013, 03:45 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
Buy your Suby axles first,,, there are various vc config s out there.. I just had mind cut and splined for $200...
76-914 |
Sep 23 2013, 04:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
pm sent
jimkelly |
Sep 23 2013, 05:04 PM
time out for you (IMG:style_emoticons/default/av-943.gif)
d914 |
Sep 23 2013, 05:34 PM
cpt tripps ,,, listen to Bob based on your config.. you have some different adapters in there already.
CptTripps |
Sep 23 2013, 07:44 PM
Hmmm...the plot thickens!
It looks like I can get a set of ADP Flanges from another member, but want to make sure I'm not buying the wrong thing. |
CptTripps |
Sep 28 2013, 01:21 PM
Got em!
From the reading I did, these should allows to use the beefy-ass axels I have already. They replace the output flanges on the 5MT and have the right bolt pattern for my axels' adapters. ...at least in theory... Attached thumbnail(s) |
Mike Bellis |
Sep 28 2013, 01:37 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The odds of your renegade axles being the right length are extremely remote. When you need new ones, check out these guys. They also sell single axles if you call them.
http://www.pacificcustoms.com/axles.html BTW, your Renegade are a 33 spline VW Type 2 axle. Most likely with 944 CV's. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:30 PM |
