martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
I drained my transmission oil a long, long time ago and now am getting to want to fill'er up again.
However, there is not a lot of room - is there a "member" in the forum that has mastered / perfected the art of filling the transmission easily - without wasting half of good Swepco Transmission oil on the garage floor? thanks, Fern |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
the container the GL5 gear oil comes in has a nozzle at top and goes right into the top fill port of the trans. fill till a little starts to drip out of trans.
Attached image(s) ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I bought a pump at my FLAPS (Friendly Local Auto Parts Store) that screws onto the top of the Swepco bottle. Put the tube from the pump into the trans, and pump away. It takes a while, but it will fill the transmission.
BTW, it's best if you fill your transmission while the car is level. I learned that one the hard way--fortunately on my Honda... --DD |
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,536 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
I use a small funnel connected to a length of clear tubing. I run the tube out the wheelwell and support it on a short stepstool. I fill the funnel until it just drips from the fill hole. Very little waste or mess. I let gravity do all the work.
Marty |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Thats easy, build on of these, I did a lot of trans / gear fluid changes in the last year. This by far was my best investment ever for this job.
Homemade gear oil pump |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
The gear oil that comes a container with a nozzle at top and goes right into the top fill port of the tranny is not hard to do. What I do is position the container near the hole before removing the cap and stick it in immediately in the hole. (That sounds dirty!) I squeeze and resqueeze the container until empty. I thought I was going to make a mess and have gear oil waste but there is very little mess.
Note: You need to have the car level. In fact, I can do it without jacking up the car. There is enough room from the rear of the 914 to fill it from. I usually put my flat waste oil change catcher under the tranny to catch drips but an old rag will do or just use a piece of cardboard. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Cut half the spout off those quart bottles. The fluid will flow more freely. Most say swepco is not good for our transmissions.
Lo-Fi Version | Time is now: 6th July 2025 - 10:12 AM |
