stefs914 |
Newbie ![]() Group: Members Posts: 32 Joined: 27-April 13 From: lincoln ne Member No.: 15,812 Region Association: Upper MidWest ![]() |
I finally got all my ignition parts in new battery wires plugs cap rotor condenser. Resealed the gas tank with the por-15 kit drained and clean all the old fuel lines changes oil and went to start it and its getting zero fuel to the carbs. I don't hear any electrical noise from the fuel punp when I turn the key to acc and I'm also not getting any juice to the plug at the top not unless my volt meter is broke.
So I guess my question is, is do I try and get new fuses and see if that changes anything? Trace the wires and try to find a short? Or buy either a replacement pump an aftermarket pump? Thanks in advance for any advice. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Where did you wire the power to your fuel pump from?
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
For me, I dislike tracing electrical problems associated with fuel while in the car. I always remove the pump and verify that it runs while hooked to a 12-volt source outside the car. I would do that first and then if the pump runs on the bench use a multi tester to trouble shoot the wires.
Fire bad! (IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/blowup.gif) |
stefs914 |
stefs914 |
For me, I dislike tracing electrical problems associated with fuel while in the car. I always remove the pump and verify that it runs while hooked to a 12-volt source outside the car. I would do that first and then if the pump runs on the bench use a multi tester to trouble shoot the wires. Fire bad! (IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/blowup.gif) Agreed!! I should've done that before I put it back into the car... Got a little to excited! (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/headbang.gif) |
stefs914 |
If it is the fuel pump what options do I have for fuel pumps do I go with an aftermarket or try to find a used one?
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
If you replace the fuel pump with a new one, it still won't work. You need to figure out why you have no voltage first. Where is this fuel pump located at? Can you post a picture of it?
SLITS |
If it is the original wiring and you switched to carbs it won't run as it is controlled by the FI system.
You will have to wire it into switched direct power or jumper the relay between terminals 30 and 87 on the relay or relay board. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,234 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
If it is the original wiring and you switched to carbs it won't run as it is controlled by the FI system. You will have to wire it into switched direct power or jumper the relay between terminals 30 and 87 on the relay or relay board. (IMG:style_emoticons/default/agree.gif) Power to the fuel pump is controlled by the FI brain. Here's a link to a thread that describes how to trick your relay board into believing the FI brain is still there: http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php (IMG:style_emoticons/default/popcorn[1].gif) |
stefs914 |
The fuel pump is located directly underneath of the gas tank.
When the car was running it had carbs I'm guessing someone else converted it along the way. Regardless I will have to check that as well. Here's a few pics if that helps. Attached thumbnail(s) ![]() ![]() |
SLITS |
From the pics, they probably pulled power from the fuse panel. You will need to check for 12 VDC on the wire at the pump with the key on.
If no power you get to trace it back to where ever the wire runs. If you have power, the Facet fuel pump is dead. |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
That is an evil noisy aftermarket pump. Look at a rotary CB Performance pump.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
when you turn the key to the point when the dash/indicator lights come on you should hear the facet pump rattling away. simple check for power to the pump in the above mentioned position at the wire. loose the old school braided lines and slotted clamps. new or used shouldered clamps are readily available. i'd invest in the access panel from the 75/76' cars. way easier to access the filter, which should be prior/in front of the pump.
stefs914 |
when you turn the key to the point when the dash/indicator lights come on you should hear the facet pump rattling away. simple check for power to the pump in the above mentioned position at the wire. loose the old school braided lines and slotted clamps. new or used shouldered clamps are readily available. i'd invest in the access panel from the 75/76' cars. way easier to access the filter, which should be prior/in front of the pump. Just to clarify the faucet pump is the one the top of next to the fill cap or the one below.. Sorry I'm a newbie like it says (IMG:style_emoticons/default/blink.gif) |
SLITS |
No fuel pump near the filler.
The facet is the one labeled Facet .... it's in your pic. |
stefs914 |
stefs914 |
when you turn the key to the point when the dash/indicator lights come on you should hear the facet pump rattling away. simple check for power to the pump in the above mentioned position at the wire. loose the old school braided lines and slotted clamps. new or used shouldered clamps are readily available. i'd invest in the access panel from the 75/76' cars. way easier to access the filter, which should be prior/in front of the pump. I checked the fuel pump is definitely getting power. Someone mentioned a rotary any other suggestions on pumps? Thanks! |
Lo-Fi Version | Time is now: 2nd July 2025 - 08:15 PM |
