wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
From all the pictures I could find it looks like it enters under the battery tray. Does is come through the engine sheet metal or the shelf surrounds.
Anyone have a picture you can post ideally feeding dual webbers? Thanks John |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Thru the engine tin, passenger side forward .... look for the hole in the tin.
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
pic
Attached image(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Thru the engine tin, passenger side forward .... look for the hole in the tin. Specifically the engine head tin on the passenger side, near the front of the motor, On the horizontal section in front of the 2 inch heater hose hole. should be a hold about 1/2 inch for the throttle cable, you may need to source a grommet. rich |
wndsnd |
r_towle |
X marks the spot....
SLITS |
wndsnd |
Thanks guys,
I got it in and set it up with the carbs. So far so good. John |
Lo-Fi Version | Time is now: 4th July 2025 - 10:57 PM |
