CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
Who's using what?
I'm finding a TON of options on eBay that range from $125-$800. I have no clue what the real difference is though. Equal Length Headers or Unequal Length Headers? Am I looking for a new oil pan too, or will the stock (2003) work? Differences in the Turbo Pipe? I want to buy now...just don't want to get the wrong thing and regret it later when it doesn't fit with what I'm doing. I realize that I'll be hunting for an exhaust too, and that it'll likely need to be a custom built pipe, but the rest of the stuff seems to be pretty important. |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Six or four? Turbo or naturally aspirated engine? You mention a turbo pipe, so I assume turbo? I have a WRX engine, used a stock STI exhaust with the WRX turbo, then a custom pipe from the turbo to the valance. Exhausts are kind of project-specific, and a lot of the automotive applications won't work on a mid-engined car. They aren't expensive, so I'd suggest you start out with stock, get the car done, then go back and change things you think need changing.
Pan depends on how your cradle positions the engine. If you need to put in a bump-out in the trunk to clearance the turbo (if your engine's a turbo) it should be the right level so you can use the stock pan. Guys who put the Subaru's into VW cars and busses don't have much wiggle room in positioning the engine, so the pan hangs down in those cars. In the 914 not so much. |
CptTripps |
Gotcha.
This is an EJ20 Turbo 4. I'll be using the 5MT transmission, and Ian's cradle/mounts. The headers on the car now were messed up and removed from the car already, so I don't have a "stock" set to go off of. I was planning on getting one of the "$119 ebay" deals to start with and then go from there when I had a little more knowledge. Something like this... http://r.ebay.com/hAyKby |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
Equal length if you can make it fit.. the sound of unequal length headers makes me gag everytime I hear it..
CptTripps |
That's what I was hoping you wouldn't say...those are the (way) more expensive ones. I'll look on a few of the WRX boards and see if I can find a used one.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Has to be equal. Otherwise you fart like every other ffBBffBBt at the 7-11.
skeates |
Member ![]() ![]() Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California ![]() |
Why not put together your own? I think that you can source the exhaust flanges at outfront motorsports and there are a bunch of sources for various bends and lengths of tubing/collectors. Tack them together and then take the assembly to have welded (or do it yourself if you are comfortable). I agree on the equal length thing. Makes a big difference, especially on 4 bangers. You should be able to find some header calculators online to give you a good estimate of lengths for the primaries. BTW, when people say "equal length" what they mean is "nearly equal length" (as in within an inch or so). It's more important for the flow path to be smooth than for the pipes to be exactly equal. I'm sure of the folks hear who have spent some time and $$$ developing headers for their day jobs have a lot more input to provide.
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
It would be so hard to due a truly equal length header. Nearly equal is good enough. I would source the flanges, and then order up the pipe. On mine I have ordered the flanges, I will grab 16 ga tube and mandrel bends and do it up. I am going to spend money on three items. The flanges and the collectors.
Narrowed it down to Cone Engineering or Burns Stainless, they also sell steel. The Collector is the best investment. After that I plan on sending it our for ceramic coating. And a coating on the inside to keep the heat in. If your good enough, you could go straight to stainless, I would rather prototype in steel, and then make it better latter. Don't forget you also ned a proper turbo flange. We had a guy in the area from the TDI crowds that I would have recommended to do your work, he was east of Lima. Welding and fab skill where top notch. He still does fab work, by day works for these guys, ![]() by night he'll do side jobs, but he's in Richmond Michigan now. ![]() And the inside, dudes got talent, my welds look like (IMG:style_emoticons/default/stromberg.gif) to his. ![]() |
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,736 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
I found a Greddy exhaust on craigs list for 150, and just picked up the matching up pipe from a guy in San diego. I got the down pipe as well to cut up for the rest of my exhaust.
914forme |
You could use this equal length header , I am sure it is one nasty piece. fit and finish wise. (IMG:style_emoticons/default/barf.gif)
CptTripps |
Never thought of building it myself. That could actually work, and would let me move the turbo to a location that wouldn't make me cut up the trunk. Hmmm...
...now I just need to get my welder fixed. |
DBCooper |
You need to be a little careful with aftermarket headers. First thing make sure there's meat in the flanges, some of the cheap ones use real thin stock that's guaranteed to warp. And some of them protrude down quite a bit further than the stock exhaust. I had one, but it was more trouble than it was worth to adapt it. My son has one, couldn't use it on his VW Bug because of clearance under the car, though it's more critical in a Bug. You might want to ask the vendors the measurement from the floor to the exhaust flange when the header's lying flat on the floor, just to be sure. And be a little skeptical of headers that don't have that expansion section between the sides. The engines expand with heat. There's a lot of pipe between the sides, it's true, but the OEM has a joint between them for a reason.
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,349 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
I went with an outfront front mount header... Looking at the install 6-7 yrs after I designed it , I had room to leave in stock location.. Top of engine department looks pretty tight...
CptTripps |
I need to see what kind of clearance I have, and if the oil pan on my motor will let me install the ELH. If not, I have to look for an STI pan, and I think there's an additional pickup I'll need to put in there. Again, it all depends on the clearance.
I'm going to stick a pin in this one for a few weeks until I can get the engine a little closer to being in the car. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Equal length headers are of less importance on a turbo setup. Cylinder scavenging due to pressure waves (i.e. tuned exhaust) is less effective on a system that has higher exhaust pressures. I would worry more about turbo location than exhaust system design myself.
CptTripps |
I found a guy about an hour south of me with a set of Perrin Equal Length headers, a Perrin Up-Pipe, and the oil-pan that will allow me to use the ELH.
I'm going to look and see, but I think I can get the whole mess for about $500. The headers go for $800, so I think I'll do pretty well, assuming they're in good shape. (Says they have about 10K on them.) |
effutuo101 |
Nice!
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
Having come from the Subaru tuner world, there is very little benefit to headers on an EJ20, unless you are running a much larger aftermarket turbo. Up-pipe, free flowing post turbo and TGV deletes along with tune will give you the most bang for $.
Pretty much all headers will warp and crack eventually. Grimmspeed offers stock manifold porting and coating here: http://www.grimmspeed.com/catalog/product_...;products_id=99 TGV delete too: http://www.grimmspeed.com/catalog/product_...;products_id=35 Port & Polish turbo too: http://www.grimmspeed.com/catalog/product_...;products_id=42 Save that money for some dyno time would be my suggestion. Good luck! |
effutuo101 |
Matt! Hijack. Would love your feedback on best tuners in San Diego. I need a forest gump. 2.5 16V with single 20g turbo now.
CptTripps |
I spent quite a bit of time with Tyler Krzynowek of TKS Autos in Barberton, OH today. These guys KNOW Subies! (There were about a dozen STIs in there in various states of tuning/repair.)
I bought a Perrin ELH, Perrin Up-pipe, STI Oil Pan, and a Crucial Racing Divorced Setup 3" down-pipe. I was out the door for $650. The Headers, Up-Pipe, and the down-pipe are nearly new. (And would have cost me about 4X as much if I'd bought it all new.) They also told me about a bunch of mods that were very "bang for buck" conscious, like the TGV delete. (Said it'd be about $150) They also have a lot of experience tuning the computers, and would do that, coupled with some dyno time after I get everything all together. I'll upload pics when I get home tonight and get everything out of the trunk. |
Lo-Fi Version | Time is now: 15th July 2025 - 06:20 AM |
