75 injection question |
rosenfe |
Oct 18 2013, 11:53 AM
Senior Member Group: Members Posts: 557 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
are the 75 injection systems more complicated and difficult to source parts?are they enough of an issue to stay away from them.
JStroud |
Oct 18 2013, 11:59 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
The fuel injection system is the same, they have an added air pump with lines going to the heads, but you can remove that and plug the holes in the heads, then back date the exhaust, and your like any other FI car.
Jeff |
rosenfe |
Oct 18 2013, 12:19 PM
The fuel injection system is the same, they have an added air pump with lines going to the heads, but you can remove that and plug the holes in the heads, then back date the exhaust, and your like any other FI car. Jeff thanks.i see your in california,as i am.im in marin county.do you know anything about smog laws changing in ca re:75 cars? as to injection i thought pre 75 were different type of injection,but im new to all this ,just deciding if i want to buy a 75 car.there is a good example available. |
wrightee |
Oct 18 2013, 12:33 PM
Member Group: Members Posts: 83 Joined: 18-November 09 From: Montclair, VA Member No.: 11,053 Region Association: MidAtlantic Region |
The fuel injection system is the same, they have an added air pump with lines going to the heads, but you can remove that and plug the holes in the heads, then back date the exhaust, and your like any other FI car. Jeff thanks.i see your in california,as i am.im in marin county.do you know anything about smog laws changing in ca re:75 cars? as to injection i thought pre 75 were different type of injection,but im new to all this ,just deciding if i want to buy a 75 car.there is a good example available. Which engine? the '75 1.8 was an L-jet system, where the earlier 1.7s had D-jet FI. Not sure, but I think the 2.0s were all D-jet...sure someone with greater knowledge will talk to that, as I don't have knowledge on the late 2.0 engines. |
TheCabinetmaker |
Oct 18 2013, 01:07 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You guys should do some searching around 914world. There is a lot of great info here.
One is a button at the very top of each page labeled 914 info. All your questions are answered there. |
57lincolnman |
Oct 18 2013, 07:52 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
I recently rebuilt the L-jet fuel injection system in my '75 1.8L. All of the components are readily available to do the job correctly and keep it stock. Busses of this vintage all use the same parts so you have another route to go to find what you need. The only problem I had was finding the throttle body switch. I had to source that from Germany. Good luck.
Lo-Fi Version | Time is now: 3rd June 2024 - 04:28 AM |
