stefs914 |
Newbie ![]() Group: Members Posts: 32 Joined: 27-April 13 From: lincoln ne Member No.: 15,812 Region Association: Upper MidWest ![]() |
Start tearing in my interior and found 4 patches that will need to be replaced. I'm trying to decide if i do the whole floor pan or not? The tunnel is good but, the chair rail center supports?(not sure what the technical name is for them) and one good size hole behind the drivers side seat. I'm a big supporter of doing things right the first time, so if that means doing the whole thing then thats what i'll do.
I'm sure theres people with tons of experience with rust and these cars so any info helps. My car is a 73 1.7 |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Two words. Restoration design.
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Once you start cutting the " patches " out to where you have good solid metal, you will find that you might as well buy a rear pan half.
P345 http://www.restoration-design.com/mm5/merc...tegory_Code=914 |
stefs914 |
I figured so I probably will end up buying a whole pan just to know i have solid metal underneath. I check at restoration design i just wanted your guys opinion first before i drop the dough.
do you really need a rotisserie for this job or does it just make it more accessible? Once you start cutting the " patches " out to where you have good solid metal, you will find that you might as well buy a rear pan half. P345 http://www.restoration-design.com/mm5/merc...tegory_Code=914 |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
Wish I had known you were in Lincoln back in September, I was up there in my 914.
Shoe (IMG:style_emoticons/default/beerchug.gif) |
scotty b |
I figured so I probably will end up buying a whole pan just to know i have solid metal underneath. I check at restoration design i just wanted your guys opinion first before i drop the dough. do you really need a rotisserie for this job or does it just make it more accessible? Once you start cutting the " patches " out to where you have good solid metal, you will find that you might as well buy a rear pan half. P345 http://www.restoration-design.com/mm5/merc...tegory_Code=914 no, you don't need one. I probably did 5 of these on the floor, lying on my back, before finally building a rotisserie. scrape all of the tar board off, go over any rusty spots with a knotted wire wheel and see how big the spots get. Post pics |
mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Where is the rust? If it's small areas you can fab up parts or get custom cuts. Otherwise (IMG:style_emoticons/default/agree.gif) restoration design Attached thumbnail(s) ![]() |
stefs914 |
hold onto your hats i was getting to the pics. Still chipping away at the floor deadener? and haven't really cleaned up the dust so this is what you get for now sorry.
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Where is the rust? If it's small areas you can fab up parts or get custom cuts. Otherwise (IMG:style_emoticons/default/agree.gif) restoration design Attached image(s) ![]() ![]() ![]() |
stefs914 |
I figured so I probably will end up buying a whole pan just to know i have solid metal underneath. I check at restoration design i just wanted your guys opinion first before i drop the dough. do you really need a rotisserie for this job or does it just make it more accessible? Once you start cutting the " patches " out to where you have good solid metal, you will find that you might as well buy a rear pan half. P345 http://www.restoration-design.com/mm5/merc...tegory_Code=914 no, you don't need one. I probably did 5 of these on the floor, lying on my back, before finally building a rotisserie. scrape all of the tar board off, go over any rusty spots with a knotted wire wheel and see how big the spots get. Post pics I'm in process of getting rid of all that junk so i really have a good handle on how much rust there really is. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:34 PM |
