911 tranny help?, shift rod seal |
Scott S |
May 25 2003, 11:17 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I am in the process of selling a 72 911. It has a tranny leak at the rear nose cone (where the shift rod attaches) that I wanted to take care of, as the leak is substantial. Pelican had the part in stock and a great tech article on completing what appeared to be a pretty quick repair. There is an easy access panel on the center hump just below the rear jump seats where this seal resides. The seal is one of those hard rubber with the internal spring type deals - about an inch in diameter. When I got into the repair, I found that my tranny has a metal pressed in bushing instead of the seal Pelican sent me. I must deduct that my tranny has been replaced. This car has 1971 as the build date on the door sticker and was sold as a 1972. Can any of you help me or provide additional info? Do I have to pull the thing and have the case opened to fix this? I know its a 911 issue, but I dont know any of the folks over there and thought I would start here first. Thanks a million! Scott S in Colo. |
MarkV |
May 25 2003, 11:22 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Shouldn't there be a pressed in bushing and a seal? (IMG:style_emoticons/default/confused24.gif)
meursault |
May 26 2003, 12:52 AM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
I'm not familiar with the tech article. I suppose this repair could be done in-car, but it might just be easier to pull the tranny. In any case, are you sure it's a bushing surrounding the shaft? Some original seals had a metal casing on the OD with a rubber sealing surface for the shaft. You should still be able to distort the seal with a punch or chisel to get it out. If not, taking the tranny out and simply pulling off the nose cone should not be a big deal. At that point, whatever you're dealing with can be pressed out.
Brad Roberts |
May 26 2003, 01:00 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I have NO idea. The person to ask is Hayden.. with WEVO. I'm guessing he is out of town this weekend (Indy 500).. he will respond to this when he gets time.
B |
Lo-Fi Version | Time is now: 12th June 2024 - 01:56 AM |
