> Hell Hole repair in process
wes
post Nov 13 2013, 06:09 PM
wes
To make a long story short my car spent almost 4 years setting outside striped at the painters and was not done properly so found another guy who quickly pointed out I have a new problem. I thought I had seen a hell hole repair kit though now that I need one cant seem to find it.
I see Engman had one but guess he is no longer around. Any one making a good one that is available now?Attached Image (IMG:style_emoticons/default/beer.gif)
Replies(1 - 19)
76-914
post Nov 13 2013, 06:25 PM
Maddog a member vendor makes them and there was one in the classified here a few days ago.
injunmort
post Nov 13 2013, 06:59 PM
restorationdesign.com fix you right up.
wes
post Nov 13 2013, 07:49 PM
wes
Murphy's law, saw the one in the classifieds but I didn't have any Idea I needed one at that time!
jimkelly
post Nov 13 2013, 09:38 PM
Delaware USA
I don't know what your welding skills are?
or what your budget is?
but your rust may be beyond what a hell hole kit was designed for?
if you have a budget, meaning some cash, you may want to touch base with mcmark at http://www.originalcustoms.com/
and have him do the stuff that is beyond bolt-on?
he is about 60 miles from you.
can we see some more pics of this area and of the rocker below, and of the same areas on the drivers side?
jim
ps - here is a good look at a hell hole repair
http://www.914world.com/bbs2/index.php?showtopic=111018
Trekkor
post Nov 14 2013, 12:32 AM
I do things...
The Engman kit was produced from my paper templates.
I'll try to dig them up and make them available.
You can see the original build thread here:
http://www.914world.com/bbs2/index.php?sho...&hl=fabbers
KT
wes
post Nov 14 2013, 12:22 PM
wes
Amazing amount of information from all, much thanks! I'll take more photos and post them later, the cars at the shop.
wes
post Nov 14 2013, 02:41 PM
wes
Looking up from under the car
wes
post Nov 14 2013, 02:44 PM
wes
Passenger side view
wes
post Nov 14 2013, 02:48 PM
wes
Driver side view
wes
post Nov 14 2013, 02:50 PM
wes
Driver side looking up
wes
post Nov 14 2013, 02:51 PM
wes
looking at driver side inside eng compartment.
wes
post Nov 14 2013, 02:53 PM
wes
The bad! note the new battrey try the 1st painter welded just above the rust!!
wes
post Nov 14 2013, 02:54 PM
wes
closer!
wes
post Nov 14 2013, 08:40 PM
wes
Work in progress! (IMG:style_emoticons/default/beerchug.gif)
02loftsmoor
post Nov 14 2013, 09:02 PM
I'll put it to the guys in the site, would it be worth while to make the parts from templates, they would be water jetted, and the proper thickness,, I don't know what grade of steel to use, It will cost me $25 to buy the templates then figgure out the rest
wes
post Nov 15 2013, 05:49 PM
wes
After it was cleaned up it's not as bad as I thought, that is it's my first time after 5 914s (just drove them) and I thought it was much more serious. The worst of it is the engine tray and surrounding metal not the inner longitudinal!
Im happy to say I am actually learning about the car I've loved for so long though I think Im going to change my name to Oldenbroke! (IMG:style_emoticons/default/beer.gif)
barefoot
post Nov 17 2013, 09:29 AM
QUOTE(wes @ Nov 15 2013, 06:49 PM) *
I did some similar work although my longs just had minor surface rust. Wire brushed that area well with cop brush on a 4.5" angle grinder, then coated stuff with Locktite "Extend". (I've had good results with that stuff) I had to buy a rear trunk panel as that was my major rust area, had enough material left over to cut patch panels for the hell hole area. i cut two panels from cardboard templates, the first one bent up along firewall and also around on side under battery tray panel. After welding this in i fitted another piece to the engine shelf and welded it in. i put a drain hole in the second panel before fitting it in. Wish i had TIG, had to use my old oxy/acetylene method.
After priming,i used some filled epoxy to smooth things out and fill that gap shown.
orthobiz
post Nov 17 2013, 10:19 AM
He doesn't really advertise it, but Brad Mayeur has some frame stuff still available on a limited basis. He's 914ltd on the site.
Paul
wes
post Apr 11 2014, 04:53 PM
wes
Well, really happy with the way it has turn out its done and new paint, now for next step!Attached Image
- Lo-Fi Version Time is now: 2nd April 2026 - 07:39 AM
