Want to Add A Start Button on Dash, ...keep bending my key |
7TPorsh |
Nov 18 2013, 12:54 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I keep bending my key starting my car. Is it hard to add a button on the dash where I can turn the ignition on with the key but push the button to crank the starter?
I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch? |
ripper911 |
Nov 18 2013, 01:01 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
On a couple of my old beetles I've had a starter button that I believe was pretty much just attached to the starter on one side and the battery on the other, usually mounted onto the E-brake handle.
I don't have them any more, and I'm not exactly sure how I did it now though... |
toolguy |
Nov 18 2013, 01:16 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
You might think about leaving everything as is at the ign switch. and add a secondary relay at the solenoid to opperate the starter. . that way you won't need a large capacity {amp} button and can run a smaller gage wire to the relay from the button. . OR you can find the wiring under the dash for the heated rear window switch and use that to get back to the engine compartment. .
The negative side of this idea is you might inadvertently hit the button with the engine running. . . OR you can pull the large yellow wire from the Ign switch which goes to the solenoid, move it to a button with a 12V jumper from the large common battery post under the dash. . . however now your button can operate the starter with the IGn switch being off or on. [think bump button] |
mikesmith |
Nov 18 2013, 01:19 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch? Make sure the button is good for at least This won't be *quite* the same - in particular it won't turn off the accessory power coming out of the ignition switch while cranking - but as long as your battery is good you probably won't notice. [edit: thanks to Tom for the starter solenoid current number... much higher than I anticipated) |
Tom |
Nov 18 2013, 02:08 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Gary,
You could do it with a start switch on the dash, but use a switch that handles at least 40 amps. Initial solenoid current is 35 amps. The better way would be to add a relay such as McMark on this site offers and also replace the ignition switch. I suspect that if you were to open up your ignition switch after replacing it, you would find arc damage and carbon build up around the starter contacts. This comes from the high inductive spike from the solenoid's collapsing field, and from the initial arc from the two contacts suddenly conducting 35 amps. Using a remote relay saves the ignition switch from these damaging events and transfers them to the relay. Relays have different alloys in their contacts to help suppress the arc damage. Tom |
Kirmizi |
Nov 18 2013, 04:47 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Ok, I'll bite.
How are you bending your key while trying to start your car? Is your lock cylinder binding or that difficult to rotate? |
JmuRiz |
Nov 18 2013, 05:50 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Mine bend too...probably need the locks all redone.
My key is toothpick thin, I'm guessing from years of use and shrinking from years of duplicates. FYI my ignition key only contacts further up the key...maybe that's something. |
dlee6204 |
Nov 18 2013, 05:52 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
If your key is bending, something is wrong and that should probably be fixed first.
Tom |
Nov 18 2013, 07:18 PM
I expect the key is bending due to the necessity of finding a good electrical contact due to the carbon build up and damage to the key contacts due to the arcing. The leading edge of the contacts is degraded, so further rotation is necessary to find enough contact area to facilitate enough surface area to make sufficient current flow possible.
Tom |
jimkelly |
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
summit and jegs both sell a nice momentary switch.
and if you use a relay like, mcmark or mark henry, suggests, then you wouldn't needed such a high amperage one but for $12 by Taylor you may as well go big and use or not use a relay in between. http://www.914world.com/bbs2/index.php?showtopic=224542 jim |
Bills914-4 |
Nov 18 2013, 07:23 PM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
I keep bending my key starting my car. Is it hard to add a button on the dash where I can turn the ignition on with the key but push the button to crank the starter? I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch? I added a starter button on my dash , but I also put a relay under the dash ,it's wired to the ignition key ,so that it only works when the key is on , I got to test it this weekend at the ramble , & I liked it , mostly because if I stalled the car I Did Not have to turn the key all the way back to the off postion and back to the starting postion , I just push the button , it's quicker (IMG:style_emoticons/default/smile.gif) , and it only works when the key is on , Bill D. i's a 40 amp relay , fuse wired to hot wire under the dash , plus grounded , I spliced into the yellow starter wire after the ignition key ,also spliced the black wire to the relay (hot key on / cold key off ) turns relay on , less stress on key switch , |
jim_hoyland |
Nov 18 2013, 09:32 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I keep bending my key starting my car. Is it hard to add a button on the dash where I can turn the ignition on with the key but push the button to crank the starter? I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch? I added a starter button on my dash , but I also put a relay under the dash ,it's wired to the ignition key ,so that it only works when the key is on , I got to test it this weekend at the ramble , & I liked it , mostly because if I stalled the car I Did Not have to turn the key all the way back to the off postion and back to the starting postion , I just push the button , it's quicker (IMG:style_emoticons/default/smile.gif) , and it only works when the key is on , Bill D. i's a 40 amp relay , fuse wired to hot wire under the dash , plus grounded , I spliced into the yellow starter wire after the ignition key ,also spliced the black wire to the relay (hot key on / cold key off ) turns relay on , no stress on key switch , Good idea. Could you make a diagram for those of us that are visual learners. (IMG:style_emoticons/default/smile.gif) |
Bills914-4 |
Nov 19 2013, 04:58 AM
Sure (IMG:style_emoticons/default/smile.gif) , no problem , give me a little time , a day or 2 (IMG:style_emoticons/default/biggrin.gif) , Bill D.
1stworks |
Nov 19 2013, 07:38 AM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
I used this starter switch pack..
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1384868299.1.jpg) I unpluged key portion of ignition used test light to figure out what i needed. Works great if i ever want to plug ignition back in iam good.Put blank black plug in column. I used wire stripper and pealed back enough wire to sodden wire extension. I have main electrical cut off for my key. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1384868299.2.jpg) |
Markl |
Nov 19 2013, 01:56 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
On both my cars, I've simply spliced in 12G wire to the ignition harness, red and yellow, and ran to the starter button. All the starter buttons I have, both "racing" and cheapy from local flaps fit neatly into the cigarette lighter hole.
With troubleshooting/tuning the DJet FI, both cars have been started and restarted many times, no issues at all. Of course, I can't light a cigarette ... |
Tilly74 |
Nov 19 2013, 02:39 PM
Member Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None |
This is what I'm planning on doing. My teener came with a push button because the ignition stopped working. Instead of putting a new hole in the dash, although small, I'd rather try this:
https://www.youtube.com/watch?v=S3HgJJpyt8o There are a few benefits to the cigarette lighter start button that I can see... 1. Allows you to keep a factory looking cigarette adapter, but now makes it useful. (I never use it, I don't smoke cigarettes.... (IMG:style_emoticons/default/smoke.gif) ) 2. Serves as a security device. Take the cigarette lighter with you if you don't want anyone driving it when you're not home, or stealing it. 3. It's pretty cool. |
JmuRiz |
Nov 19 2013, 03:42 PM
Cig lighter mod is REALLY cool!
nsyr |
Nov 19 2013, 06:37 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
jimkelly |
Nov 19 2013, 06:57 PM
its cool until someone who smokes presses that button, while you are driving, before you can tell them NOOOOOOOOOOOOOOOOOOOOOOOOOO!
I think momentary switch has got to be protected or hard to reach. |
Bills914-4 |
Nov 20 2013, 07:45 AM
I keep bending my key starting my car. Is it hard to add a button on the dash where I can turn the ignition on with the key but push the button to crank the starter? I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch? I added a starter button on my dash , but I also put a relay under the dash ,it's wired to the ignition key ,so that it only works when the key is on , I got to test it this weekend at the ramble , & I liked it , mostly because if I stalled the car I Did Not have to turn the key all the way back to the off postion and back to the starting postion , I just push the button , it's quicker (IMG:style_emoticons/default/smile.gif) , and it only works when the key is on , Bill D. i's a 40 amp relay , fuse wired to hot wire under the dash , plus grounded , I spliced into the yellow starter wire after the ignition key ,also spliced the black wire to the relay (hot key on / cold key off ) turns relay on , no stress on key switch , Good idea. Could you make a diagram for those of us that are visual learners. (IMG:style_emoticons/default/smile.gif) Here's a quick sketch , I used a dunebuggy starter button (rubber boot button) you really have to push it to make it work (you don't want a sensitive button ) (IMG:style_emoticons/default/biggrin.gif) , I hope this helps Bill D. 12527647e9129233622_1_.bmp ( 511.38k ) Number of downloads: 64 |
Lo-Fi Version | Time is now: 9th June 2024 - 02:04 AM |
