rear window, weather stripping |
grasshopper |
Dec 25 2004, 07:17 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
Anyone know where to get weather stripping for the rear window? not the part that goes right above the engine compartment but the seal that goes around the rest of the window?? is there a seal there? my window is getting kinda shaky when the top is down. Thanks and Merry Christmas!!! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Trekkor |
Dec 25 2004, 08:00 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
No problem, 3M make a peel and stick glass seal.
You can get it at the auto store. cheap, too. Just cut to fit and schtick in there. KT |
grasshopper |
Dec 25 2004, 08:38 PM
Thanks for the info. I didn't know if there was a certain seal that was supposed to go there
SirAndy |
Dec 25 2004, 08:58 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
nope, just the standard buthyl (sp?) automotive tape (black gooey stuff) like trek mentioned. every bodyshop/glassshop will have it ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Carlitos Way |
Dec 26 2004, 12:22 AM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Mine is shaking too.. but it seems to be also held in place from the inside by the backpad... and my backpad isn't in the best of conditions. ANy suggestions?
I hate rattles!!!! |
McMark |
Dec 26 2004, 01:37 AM
It's called 3M WindowWeld and is spelled Butyl. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Rusty |
Dec 26 2004, 09:24 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Yep. Pull out your backpad, and while you're having it recovered (probably a c-note at your local auto restorer)... fix the rattle. The butyl is stiff when cold, and gooey when warm. You need to get it rather warm (almost melty, but not quite) for it to seal best. So, depending where someone is, that means a warm garage and a heat gun. The glass should be very clean and the seal channel, too. Residual butyl can be cleaned off with Goof Off or something similar. For cleanup, use latex gloves. For installation - clean, bare hands. |
Eric_Shea |
Dec 26 2004, 11:59 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Try this thread:
Rear Window Fix Most original Butyl will simply fall right out with a putty knife. It's old and hard (which is why your window is rattling.) |
Always Looking |
Dec 26 2004, 05:05 PM
Member Group: Members Posts: 194 Joined: 9-December 04 From: Orange, CA Member No.: 3,246 |
I got my window-weld from AutoBodyDEPOT.net. They shipped quick. The total cost was like $18.00. The only question I had was what diameter. I ended up getting the 3/8 inch diameter, which works. This size was suggested by Pelican Parts. I seems like it might be a little thick, but I have no experience in this area.
Good luck, (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) |
jwalters |
Dec 26 2004, 05:27 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Thickness is good--you gotta press the glass firmly into it--the more "squeegees" out, the more to hold the glass in place............
(IMG:http://www.914world.com/bbs2/html/emoticons/drunk.gif) |
Elliot_Cannon |
Dec 26 2004, 10:51 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I went to a local auto glass shop and they GAVE me enough to do two windows! If you think the seal is too thick you can stretch it and make it thinner. It's one of the easier fixes on these cars.
Cheers, Elliot |
Lo-Fi Version | Time is now: 11th June 2024 - 04:01 AM |
