Centre mount parkbrake?, Centre mount parkbrake |
rhd914 |
Dec 26 2004, 03:05 PM
Newbie Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
Hi, I wondering if anyone had bothered to relocate the parkbrake lever to the centre of the car?
I am looking at doing this on my '73. I just bought a park brake lever from a 964 because the whole assembley sits above the tunnel. If you done this, tell what and how you did this and a photo if you have it. Thanks Geoff. |
Jeroen |
Dec 26 2004, 06:24 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
I'm considering it. You'd prolly need custom cables
Some of the factory 914 rallye cars had center mounted handbrakes Check Jon Lowe's Gt-info pages for pics of those... (sorry, don't have the link at hand) |
Eric_Shea |
Dec 26 2004, 06:30 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I've got the rear 911 e-brake system done. I have the early 911 hand brake handle. I've yet to locate it on the tunnel. I will though (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
d7n7master |
Dec 26 2004, 07:02 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Why???
URY914 |
Dec 26 2004, 08:42 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Why all the effort? Cool factor? P |
SirAndy |
Dec 26 2004, 08:46 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
makes for faster drifting around tight corners because you don't have to switch hands on the steering wheel to (P)-Brake and then downshift. your hand is on the "right" side already, so your left hand stays on the steering wheel ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
URY914 |
Dec 26 2004, 08:51 PM
Shit, I've been doing it wrong for 25 years!!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Hand brake turns in a 914? Come on. P |
d7n7master |
Dec 26 2004, 09:26 PM
I've got a lot to learn. Never used the hand-brake to turn - 'cept in a sandrail.
Don't you need two??? |
SirAndy |
Dec 26 2004, 09:32 PM
hell ya! go straight fast, wiggle the steering wheel just a bit right before the turn, press in the clutch, apply handbrake. your ass comes around nicely. (clutch still in) downshift. release clutch and apply throttle ... in order to do that fast (with the handbrake on the left side) one would have to let go of the steering wheel at one point while releasing the handbrake and downshifting. with the handbrake in the center, you can do both fast with the right hand while still steering with the left. try it sometime, it really works! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Andy |
Aaron Cox |
Dec 26 2004, 10:27 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
or a dual position one for cutting brakes |
914Timo |
Dec 27 2004, 01:14 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
You could use wider seats. With my OMP seats the hand brake is PITA. |
Mueller |
Dec 27 2004, 01:22 AM
to put it where it belongs....just like how the ignition switch is in the wrong place on the /4 cars (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)....hahahaha |
Eric_Shea |
Dec 27 2004, 09:38 AM
Not really. I'm too old to be cool (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Mine started with a standard brake upgrade to S-Calipers and a 911 Koni front suspension. I then needed to add the 911 M-Caliper rear caliper. I then had no handbrake. I was upgrading my 911 to aluminum rear control arms. I had an extra set of 911 e-brake assemblies. I heard they fit. I tried it and they did. I had an extra 911 hand brake from an earlier project. I saw some factory "rally" GT cars with the 911 handbrake
Tired of short ramblings? Summary: I wanted a larger brake "system" and the only way to get a good handbrake was to use the 911 e-brake assembly. I like the idea of center mount better and I had all the parts. I've yet to mount the handle but it will be soon (as soon as I get this damn 914-6 out of the garage) (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
Rough_Rider |
Dec 27 2004, 10:28 AM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
If you wann be really clever.... & only for handbrake turns install a 4th foot pedal which solely connects to the rear calipers.
Then you can do all those handbrake turns without taking your hands off the wheel. Similar setup has been used on rally cars in the past before hydraulic handbrakes came into play. McLaren F1 fitted some of their cars in the 90's with 4 pedal. No pedal accutated cluth though. Clutch is by hand. They had main brake pedal all 4 wheels. Left side brakes, Right side brakes. & Accelerator. Heading into a tight turn drivers could drag the inside brakes & eliminate understeer. Same principle was used during the active suspension F1 era. |
boxstr |
Dec 27 2004, 08:13 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
If you take a look at teh Boxster the park brake is located in the center. That might be a good option.
CCLINPARKANDRIDE |
airsix |
Dec 28 2004, 01:08 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
handbrake in stock location can interfere with: race seats roll-cage frame reinforcements -Ben M. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:25 AM |
