Auto Meter Pro-Control Rev Limiter, Anyone using this on stock fuel injected engine? |
toadman |
Nov 28 2013, 02:44 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Happy Thanksgiving everyone!
Is anyone using the Auto Meter Pro-Control rev limiter unit on a stock fuel injected 1976 914? How about on a stock FI car with a Pertronix Ignitor points replacement unit in the distributor? I am currently using a Pertronix Ignitor points replacement unit and the Bosch rev limiting rotor with a rev limit close to 5800 rpm. The mechanic that rebuilt my 2.0 liter engine says he is confident that I can go to 6200 - 6400 rpm for short periods without damaging the engine. The car is autocrossed and used for DEs during the summer and there are times when I am hitting the rev limit but I want just a little more speed before the next maneuver. Anyone have any experience with these units in said applications? Thanks |
Mike Bellis |
Nov 28 2013, 04:12 PM
This type of limiter typically is installed inline with the coil trigger and interrupts the signal when a programmed level is reached.
I don't think you will have an adverse effect on the FI system since the 914 uses a primitive ignition system. |
Mark Henry |
Nov 28 2013, 05:03 PM
No point in over revving the stock engine, it's run out of legs by the time it hits 5800rpm anyways.
Lo-Fi Version | Time is now: 6th June 2024 - 07:32 AM |
